Steering stabilizers and Carli 3.25 lifts
So I figured I would post an update with my feedback. Here is the deal
Carli backcountry 3.25 lift, track bar, sway bar, add a pack, running 37x12.5x20 on 20x9 +20 offset
I ran this configuration with the stock stabilizer and the Tharen King.
With the stock - I never had any problems with the stock stabilize, put about 150 miles it with the setup above with no issues.
King - It makes the steering seem tighter/ firmer, at slow speeds it seems to push slightly to the right but not a lot. Not to the point it bothers me. At highway speeds I don’t notice any pushing at all.
Summery. I think I need to put more miles on the King but at this point my assessment is that had I not already bought the King I would be more then happy with the stock stabilizer.
Thanks for the follow up. My '23 has a bit of float feeling to it with 35" NIttos. I have been looking into a King/Thuren stabilizer but I am starting to think this is just the nature of the 35's I have and a stabilizer isn't going to fix a problem that is just a side effect.
Do you have any further thoughts since its been several months now?
How do you like the 37s? I am getting my Carli lift (3.25 backcountry with add a pack and Carli sway bar) and 37 s installed next week. I just finished a 2500 mile road trip on my stock 2023 3500 Limited and was very impressed with how smooth it road, night and day over my 2014 3500 Longhorn. I am hoping to keep the same ride quality.
I have that set up with over 10K. Very happy with the system and Carli.
That’s most likely either tire pressure or alignment. A steering stabilizer won’t help with any of that.
What pressure are you running, and have you had the alignment adjusted to Thuren specs? The factory alignment has unnecessary toe (solid axle vehicles shouldn’t have any toe) and it can cause wandering, which is exacerbated by overinflated tires, especially if they’re larger with more aggressive tread.
I do think its the Nitto hybrid tires pulling a bit. It's not much at all. The alignment is 100% thuren specs. I actually think it's okay because it pulls a bit in the right lane and bit to the left in the hammer lane.
I ran my Carli lift and 37s with the stock stabilizer for a few weeks with no noticeable issues. Had I not already bought a King stabilizer I probably would have just left the stock one on.
I am installing a 3.25 backcountry kit on a 2023 3500. In the past I have run the Blistien dual stabilizer but I got a lot of corrosion on the body’s. I would like to run the Fox ATS but CJC says they it hit the Carli track bar. BDS says their dual stabilizers will only work with 4” lift??
For those of you running the Carli 3.25 on a 2019 and above..what are you using.
Carli makes both a low and high mount SS-- on the pintop 3.25, I would use both. I have the Carli 2.5" pintop and am running the low mount, about ready to add the upgraded radius arms and high mount SS as well...
Why?
It has been awhile since I researched all this but if I remember right only having one nitrogen SS tends to “push” the stearing to one side, dialing in the right amount of pressure can be challenging. Having two opposing nitrogen SS tends to neutralize that affect. At least that is the way I remember it.
I ultimately went with one King SS but honestly I don’t think I noticed a significant difference in performance from the stock SS and I am running 37”s. I used to live up in New England so I had it wrapped. I am down south now and is not a worry for me anymore
Sorry, I was more asking him why he changed out the steering stabilizer.
