Battery Saver Mode
Hey guys same thing here, 2019 HO.
Mine comes up with battery saver mode once daily after first start of the day no matter what outside temperature is.
Been to the dealer four times, every time the tell me battery’s pass load test, they update or install new flash, but doesn’t fix anything.
Tech found amp draw on abs module and said he suspected that to be the problem. So I asked if they replaced it.
He said no he just rebooted it and that if it happened again they would replace it.
Next day same issue! Took truck back again.
When I picked it back up for the fourth time asked if they replaced abs module as they had told me they were going to do. Was told (no we can’t just throw parts at it) we rebooted it.
Fed up! They have no clue!
I have been having the same issue for 3 years too.. and I just picked the truck up from the dealer last week and a couple days later had a "Service ESC" light come on. Looks like my ABS system has gone haywire. Its interesting to see the same thing on your truck. It goes back in a couple weeks to have the ABS issues looked at.
Changing batteries did not help mine. Well it did at first but it eventually came back about a month later. I have replaced the ibs on the battery and have not had the issue for a couple of weeks now. There is an updated part number and the part is slightly different than the one on my 2019 truck. Part number of the ibs I bought is 68370876AB
thanks! ill have to try that part before the fire happens just to see if that helps
Revisiting my post above. My battery saver mode would come on reliably every cold morning at about the same distance from home. After I did the steps above, I haven't seen the message again.
I've also been having the same issue. 2019, 3500 brand-new batteries approximately 53* abeyant temp outside. Truck started up fine after a heating cycle and volts were about 14 on the battery. drove for a few miles and the truck went into what I call battery limp mode. so frustrated with this issue. I was starting to think maybe there is a short in the grid heater bolt that is causing this message to pop up since there is already so many issues with that.
I'm interested in seeing pictures/ hearing more about your rewiring. Thanks for the help!
For those with a diesel, those cabin heaters are a huge current draw and if you don't have dual alternators, I think you're more likely to see battery saver kick in with a grid heater start and cabin heaters running.
If it's not colder than 0-10F, just push the button twice and the truck will start without needing a preheat.
Will add my truck to this. A 2019 2500. Been doing this every winter since I bought it new. Brand new batteries this fall and still doing it. Don’t even bother taking to dealer as seems if there is no code they are useless. Been seaeching the web every year and doesn’t seem to be an answer that completely solves this issue. Would think by now Ram would have this figured out as seems pretty much every 2019 experiences this. Anyone get a complete fix?
I have never had this nor the many people I know with 2019s
Has anybody actually tried this replacement part? If so, has it worked for the long run? Mine will be fine for about two weeks after I fully recharged the batteries with an intelligent charger, but the drainage loss occurs and the problem resurfaces. So far I charge the batteries every two weeks or so.
Thanks for any replies.
Does your truck get used daily for more than 5mins drive time?
No, l’am retired (2.5 years) and use it occasionally. However, this has been going on for 5 years, and it was a daily driver before and more than 30 miles daily. This truck has had this problem since new.
Yea i got the same problem, what's weird is when it was REALLY cold last week no issues, this week the weather got a little warmer and all the sudden it's back. I reported it to the NHTSA, i figure if enough of us complain they'll look into it. I'd put my money on a canbus module firmware glitch since it's ONLY the 2019 models so far. When the ambient temperature is in X range it causes an error and all it needs is a firmware update to fix this glitch.
I have a 2018 2500 and this is happening to me! It is truly maddening!!!! I bought used with 24k miles about 3 yrs ago. It didn't happen the first year. Dodge installed new radio since they thought maybe had something to do with the touch screen. Not only does it shut down phone connection, radio, heated seats/ steering but it gets stuck in climate screen. My husband looked at some forums and said it seems normal. IT should NOT do this is my opinion. Something is def not right. I didn't pay 100k but I paid 69K I shouldn't loose any functions on the dam truck at any time! I know a lot of these posts are from 2021 I'm hoping to come across something more recent with people having success with fixing this issue
And I might add there is no Rhyme or Reason for when it decides to do this besides cold. The truck set for a damn 3 days I didn't have it plugged in and it's been 20° out dropping to 12 at night. I got in and drove it even using remote start was perfectly fine got to my destination went in for about an hour... came back out and started it and it was in battery saver mode. When it was happening to me last year before they replaced the radio/ screen.. and turning off the ignition and turning it back on would turn the battery saver off sometimes
How old are your batteries?
coming up on 3 years with this problem, i lost count of the times its been to dealer, even had FCA involved last year and it still goes into "battery save on "mode....dropped it off at dealer sunday night for a monday apt. for a water leak in rear window area and on the way to dealer the "battery mode on" came on so i again added it my list of what needs fixing.. this dealer is one that i didnt buy ram from but they have been really nice to deal with and seem to know trucks better than the stealer ship i bought ram at... POMOCO ram in newport news virginia. (they are absolutely the epitome of bad service)
service adviser call me this am and they fixed the water leak (third brake light gasket) and we talked about the "battery saver on" mode and he asked me more details about how the problem starts. he said they tested batteries and they are within specs but on low side and they tested the alternator and it was within specs BUT the tech noticed a slight smell of electrical smell in alternators area. i told him i have been having this for almost 3 years no thyme or reason when it decides to flip out, i told him the alternator gauge reads 11.3 upon start up and i turn on the heated seats etc and the volts on meter still stay at 11.3 and then for no reason it will decide to start to increase voltage. ( i told him that i have mentioned that i have told dealerships about the smell and most looked at me like i was crazy, i told him im retired firefighter and i can tell electrical smells over paper etc, ) he said there were no codes stored and i said well i have the pic of the mode on and the milage sitting at their bay sunday night when i dropped off truck. he said he believes me. but after this whole ****show a tech finally said he smelled an electrical smell ) i told him i hope the truck catches fire, he said they were gonna run it and drive it to see if they can get it to duplicate it. he said FCA is a pain to deal with and he agrees the engineers at FCA/ram need to actually work and turn wrenches on these trucks. finally a service guy who agrees with me. sooooo in the mean time im hoping the ram burns up and is a total loss. i sure do miss my 2004 ram 2500 4x4......it had 0 issues. this POS on the other hand....well i just hope it burns down to the ground.
I'm right there with you! I miss my 06 Cummins 3500 DRW.... I may be leaving Ram :(
well... from everything I've read here is my take. Turn off heater, radio and reprogram for my heated seats/ steering wheel to NOT auto turn on, make sure any charge cords are unplugged, plug the dam block heater in, do not use remote start, pull up as far to my fenced area next to garage & trailer to mitigate cold air flow to engine and MAYBE it will not go into power save mode.... or sell- buy Ford or GMC :(
original OEM my hubbs was reluctant to change those out until they actually go bad because all the stories he's heard of people changing them prematurely and it doesn't really fix the problem. 6yrs maybe 7 I was going to go get them tested today cuz I have an appointment with the dealership tomorrow dropping it off for Tuesday. After reading everything on here I don't know if the dealership is just a waste of time.
Replace the batteries, that's most likely your issue. The OEM batteries don't last anymore and most fail in 3-4 years so 6+ is pushing it.
Problems are caused by not changing them, not by changing them prematurely (thou you're not premature since you're experiencing issues).
