New Wheels and Tires Installed
TophandRam
Florida
Well I decided to get my tires mounted on my new wheels and then Install them at home.
I had purchased an new tackoff set of 2020 Laramie lImited Wheels and tires but since I am going to larger wheels and tires these came off and I will sell those only had 1500 miles on them.
I went with an Ultra (made in the USA) wheel "villan" new for 2020 its a 20x9 +18 specifically for the leveling kit I am going with next week, I have Nitto Terra Grapplers 35x12.50 20's.
Since I added the 2019 Ram Power Wagon fender flares the tires fit perfect right on the edge of the fender flare which is the look I wanted.
Added new TPMS , they do not rub at all but I am not concerned since next week I will install the Carli Leveling 2.5 kit with the track bar and stabilzer shock.
Also purchased all of the Mopar Black emblems , hood, Cummins, RAM, and 4x4 they look good on the red truck.
Did you get the PW flares from the dealer? Also, I have a tradesman, did they attach easily or was drilling involved?
Looks good.
Looks good.
I posted the information about the flares you can see the details. https://hdrams.com/forum/index.php?threads/fender-flares.228/page-5#post-29668
They are MOPAR 2019 Power Wagon parts paid about $160 total with shipping,
1. You have to remove the lower black trim pieces lower front fenders, front / back trim rear wheel well and remove all of the inner fender black screws.
The approach I followed was from another member who installed them on a 2017 or 18 2500.
The OEM flares have the mounting screw holes already no drilling required unlike the clone or know off Chine made flares.
2. All of the white clips that are push in for the factory 2019/20 Rams with original fender flares holes, since mine did not have those i used 3M double sided body trim tape (Home depot)
3. You will have to cut off all of the push pins, and two or three molded black alignment pins you will see them on the fenders.
4. On all of the white clips you cut and attach 3m tape to all of the trimmed white clip parts, I did one fender at a time and installed it then did another one.
5. Remove the red plastic off the 3m tape and carefully align the fender flare with the correct body lines and groves work from the bottom up and slowly press the fender to the body so the tape adheres.
6. Align as needed , insert black screws you may need to use a small scribe to align each screw hole worked for me.
7. Rear fender flares upper wheel well you will have two holes with no screws like the inner fender screws, i chose to utilize a 3/4 " long phillips type screw , flat washer, then a flat/lock washer and nut for the inside.
I used some black touch up paint to match the other screws.
8. These fit very well since they are factory parts, to date my tape areas are still in tact and they look great, they add about 3/4" more coverage than the stock painted ones.
