dvpvic
Im not sure how it works but in alphaOBD you will enable the feature to workHopefully the one I purchased will work
Do you happen to know does these fuses need to be turned on? Under the hood.
I am not an expert but how I understand it is the cable you got is a "SGM?" and you will need access behind the cluster (which is a PITA to get to) instead if you use the cable I linked (and I use) it plugs into can buss modules just above your e-brake. Heres what others on forums have said;I've seen the cable you just posted. I just wasn't sure of the website. I went with something I found on Amazon in reviews someone mentioned this is why they purchased it.
I just purchased this cable yesterday. Should have it tonight.
Brand: TTXSPP
Cable Adaptor for Chrysler 12+8 Programming Cable Connector
"HD SGM is not as accessible and is located behind the instrument cluster, hence the confusion for some. Since it's such a PITA to get to, we use a different bypass cable that plugs into the CAN bus blocks. ETA: Said cable can also be used on the 1500 if desired."
I'd search around forums, youll find most use one that plugs into the can bus modules.
