Samuel Vicente
My dear friends from the forum, my name is Samuel, and I’m writing from Brazil. I’m experiencing an issue with my 2020 RAM 2500 6.7 regarding the electric fan, where it makes a VERY LOUD noise in certain situations.
It’s important to note:
I appreciate the opportunity, big hug to everyone!
- The truck has an SFI remap (a renowned Brazilian diesel tuning company) and a K&N performance air filter;
- The temperature always stays from the middle down, it never goes beyond that. I always monitor it on the analog gauge and the digital dashboard. Some time ago, it used to stay only in the middle, but now it stays from the middle down after installing the filter;
- The noise only starts when I turn on the air conditioning; otherwise, it doesn’t happen;
- If I start the truck with the AC on, even after turning it off later, the electric fan doesn’t turn off unless I go to the highway and maintain a higher speed above 100 km/h. However, in the city, it stays on 100% of the time at lower speeds;
- The noise is literally coming from the intercooler’s electric fan, as if the truck is cooling down from being hot, but it happens even when it's completely cold after sitting for days. If I repeat the process as mentioned above, it behaves the same way, and the only way to resolve it is to stop the truck, turn it off, and switch off the AC, then restart the truck with the AC off. Or, start the truck with the AC already off. It's important to highlight that even if I don’t turn on the AC compressor but only the fan, it behaves the same way;
- As mentioned, if I start the truck with the AC off, it behaves normally without any issues. The problem only arises when I turn on the air conditioning.
