LETS SEE THOSE 35'S ON STOCK WHEELS
It's been a great tire. Probably have 34k miles on them. Plenty of tread left but starting to get noisy.
I love them. I had the Baja boss A/T’s in 295’s before these and those were good too. These have a slight hum but it get drowned out with the radio
I just recently joined the 2500 Cummins club. What kind of mileage drop did you guys see with 295/70r18? The at3 xlt’s look good!
I lost about 1 MPG going from stock to 35x12.5 toyo at2 on stock wheels
Other than the 1 mpg loss did you notice any loss in performance?
After almost 5 years - went from Cooper AT3 XLT in 285/65/20 to Toyo AT3 in the same size - Had a bad flat about 90 miles from home on Sunday, good ol' boy in a tow got it pumped up with 4 plugs (2 pocket knife blades in my tire, must have been a multi-tool/leatherman in the road) and I hauled ass home, once the tires cooled when I was home had a slow leak, so wasn't worth salvaging, and based on age, I was due.
Love everything about the Toyo's more, in every way basically - I do think the Coopers were 'wider' in the same size, based on Tire Rack specs and lining both tires up before Discount Tire mounted them - sidewall differences, lugs etc, it wasn't much, but I could see a difference.
I am debating going up to 295/65/20 AT3's, under Toyo's 500 mile trial program, which Discount Tire said I could absolutely do if I wanted a different size. However, 2 things holding me back are more radius arm rub (on Coopers, had a touch on left side radius arm only, I need to check these 285/65/20 Toyo's under full lock), and the fact that I am pushing it with gearing as I have a 2018 with the 3.42 gears, on a SRW 2500.
Will get pics up of new current 285/65/20 AT3's, they are on 19+ Night Edition wheels which I had powdercoated gloss black a few years back. Toyo's balanced great, most one wheel took was 1.75oz - one tire took .5oz to balance, the Coopers had long strips of weights in comparison.
Is yours stock height? Im thinking of getting these exact tires and size, was curious if they would rub or not at stock height.
Height does not matter stock or leveled. Wheel offset does. On stock wheels you may rub the radius arm a touch at full lock, or not - you won’t feel or hear it
Truck is stock height. I didn't feel any rubbing, but there was a small clean spot on the suspension arm. Not enough to remove the paint in the 3 years they were on there.
