DownShiftz
I purchased these from Amazon. https://www.amazon.com/Puddle-Lights-Driver-Passenger-2010-2019/dp/B07ZLZSG4Y but there are many types/styles available from other vendors such as Recon.Would like to see a pic of those and install info
Fit is perfect and plastic is the same color and texture of OE. The originals pop out by getting a very thin flat head under the lip and pry. It’s near impossible to not put a small dent into the plastics but no worries you’re throwing those out anyway. The replacements came with male spade connectors on each wire. The originals on my truck are attached with a 2 pin connector. I cut the male connector off the OE’s and then soldered/heat-shrink them onto the new ones. Plug the new ones in and they snap in with 3 retention tabs. Easy and cheap.
