Cold mornings. The past week and this week they’ll be high 30’s low 40’s in the mornings and mid 60’s daytime.
12 mile highway run to work this morning, truck started at 12.5% soot on the dashboard gauge. 5 minute warmup before I left. Exited my driveway with an engine at 168°F and EGT 1, 2, and 3 all reading 500-550°F. Within a minute or two on the highway, all three EGT’s were 650°F or higher, and stayed that way for the 12 mile run at 75mph. In some cases, while cruising up a few light grades, the EGT’s all climbed in to the 750-800°F range for a few minutes. This behavior is likely why I’m getting better passive regeneration and am able to maintain the 24 engine hour cycles in the colder months. Looking back at my documentation over the past year or two, my trends show the 24 hour regen cycles typically start around October and stay that way until about April. Based on what I’m seeing on the iDash this morning, this trend will likely continue this year as well. DPF % REG is now being driven by the regen timer, not soot since I’m over the 12 hour mark. I’m 18’ish hours since last regen (and somewhere around 600’ish miles) so this tracks with the iDash PID. About 2 miles from my work, the dash gauge dropped to 0% soot and I’m sure, as long as the weather continues this way, this will likely be the way it goes for the next several months.
Colder temperatures = a cold engine that has to work a little harder, thus increasing EGT’s into a slightly elevated state. This elevated state is over the threshold for effective passive regeneration, so it’s easier to get the truck to begin converting soot. Add to this cooler denser air, which should make the truck operate more efficiently, and the result is far easier achievable 24 hour regen cycles.
I guess we will see if my hypothesis and predictions come true in the coming days weeks and months.
