oledirteh
How do I know when it was made can you check using the vin
if its on there, may be on the door jam
mine has been trowing the code as well and fuel in the oil been in dealer 3 weeks now there replacing a map sensor and new air filter and giving it back to me can’t see it fixing the crazy amount of regens but we will see I’ll keep you informed but mine is a 21 so I guess they won’t replace my dpf
Exactly. Your own case and experience is proof that they’ll negligently spend three or more times the replacement cost of a truck in an attempt to dodge or avoid having to replace a truck. Imagine the money they would spend in court willingly….100% they could care less about the average guy. They have enough cash back to out weigh you in court. They will lose 100% but you have to get to court first and thst could be $10k-$30 in lawyer fees. They will just kick this all down the road till it goes big class action 5 years from now.
Like I’ve said, they know the issue they just can’t admit it. This TSB hopefully rips the bandaid off and we can see what the actual issue isExactly. Your own case and experience is proof that they’ll negligently spend three or more times the replacement cost of a truck in an attempt to dodge or avoid having to replace a truck. Imagine the money they would spend in court willingly….
I’m already predicting a bunch of these trucks will have the TSB applied (DPF replaced) and will be returning within a few months at most with the same issue.Admiting it will cost them a lot. It will probably trigger tons of recalls and buy backs. I honestly believe its why they won't just give me another truck.
Complete agree. The DPF isn’t making the soot that fills them up.I’m already predicting a bunch of these trucks will have the TSB applied (DPF replaced) and will be returning within a few months at most with the same issue.
My DPF was replaced last April and the truck seemed to function more or less as intended. My gut told me it was a bandaid, and a temporary one at that. And wouldn't you know it, 4 months and less than 8k miles later it's starting to get regen cranky again (I started noticing it in August). It's taking longer and working harder to passive regen, and I've had 2 soot based regens in the past 4 weeks. Absolutely nothing has changed with my driving routine, and the weather is much cooler now. My shiny hunk 'o junk does fall into the TSB manufactured date range, but if all they're going to do is change out the DPF, again, I have no hope left for it.I’m already predicting a bunch of these trucks will have the TSB applied (DPF replaced) and will be returning within a few months at most with the same issue.
Exactly what I was thinking as well.It will fix a percent of them and a few they might never see again because people drive them very little. This will keep a lot of truck away from dealers all a percentage game for short-term fixing.
Maybe it'll be a newly designed DPF and software update...., can only hope!
lol, damn Cummins.Hope it can just catch fire and we can get faster results lol. I've been hoping my motor would just blow up already so I can just move on.
I'd like to chime in here to add my experience to this issue.
I have a 22 2500 Cummins with the same issues as the OP. I've been having issues since about 8k miles, now I'm at 22k. Frequent regens, around 30-60 miles between regens, some more some less. Throwing P2459 codes and it's also "making oil." I sent in a sample to the Cummins lab, which came back at 7.4% fuel dilution, putting it at level 4 "severe." That oil only had 4110 miles on it. I changed the oil at that time, with 11.5 quarts, putting the oil level right at the middle of the "safe" zone on the dipstick. Now, a little over 3k miles later, that level is WAY off the stick and somewhere on the metal cable. I'm pretty worried about what this is doing to the internals of my engine.
I've been trying to do everything by the book. Not letting the truck idle, limiting short trips, following all the maintenance intervals, blah blah blah. I have a 25 mile highway commute, each direction, with no stop and go traffic. And for the record, I do have the correct air filter installed.
I dropped the truck off at the dealer this morning and their tech told me about that TSB that just came out, which they confirmed applies to my truck. They ordered the DPF with an ETA of three weeks. I've been lurking on this, and other, forums researching this issue. I don't have a lot of confidence that replacing the DPF is going to actually fix anything. Others have reported that replacing the DPF did nothing to fix the issue on their trucks (same year, same issues). The dealer already replaced my MAF with the Chinese version. That did nothing. I'm going to give RAM a few more shots at trying to fix the issue before I go the lemon law route. I'll tell you this: It'll be a cold day in hell before I buy another modern diesel.
It really sucks. I really like this truck and it tows like a dream, which is why I bought it. I had every intention of keeping it for the next 15-20 years as my daily driver and tow rig. Even if they do fix it, what did this oil dilution do to my engine? Can I even trust it not to blow up on me after all this?
Just got back from the dealer. I asked for an oil change under warrantee, which they denied because it wasn't specifically approved per their TSB. The service advisor recommended I call RAM customer service to push the matter. I went back and forth with customer service and the service guy with no luck. In the meantime, I'm running on diluted oil. I think I'll do a dump and fill and keep the old filter running this weekend, just to get that old oil out. Maybe I can push for an oil change at the time of the new DPF.
I'm not impressed with the level of service from RAM. You'd think they would want to keep an expensive engine from grenadeing and make a customer happy. Apparently not. It seems the dealers can't even wipe their own butts without RAM signing off on it.
