Good evening, all,
Some things that should be looked at and considered if you're the "proud" owner of one of these engines.
As a servicing dealer, Cummins has upgraded the oil requirements for the engine to insist that Valvoline Super Blue 8600 series 10W-30 SYN Blend or preferably Full synthetic oil be used. They have stated not to use 15w-40 anything in the 6.7 engines to prevent valve train issues. If you're going to be where the mean temperature is 0 and below, they want us to use 5W-30 of the same.
On another note, for those that are in warranty and those that are not, if you have the stock air intake heater, check the connector to the element on a regular basis. If it wiggles, stop driving it. The heater element is held in there by two poor quality bolts that corrode and can drop into the intake. Generally winding up in cylinder #6; bad news.
Once out of warranty we are installing the EPA approved appropriate Banks Elbow Kit "Monster-Ram Intake System" for example: Black, Key feature: 72.7 lb./min Mass Air Flow, +88.3% performance gain over stock fitment: For 2019-2024 Dodge Ram 2500/3500 6.7L Cummins Diesel. These have the heating element in the shell of the elbow and remove the flow restriction in the plenum caused by the OEM units and the failure potential problem.
