Did the water spot remover with vinegar a few weeks ago and the process stained the concrete.
Absolutely the BEST at removing water spots, I have tried soooo many different products and I will never use anything else now!!! One clean towel to wipe it off, let it dry to a haze and gently wipe it off with a dry towel. I only use it after I wash my truck, I would never trust any “waterless” spray to actually clean my truck…IMG_3350.jpeg
Just returned from a two week road trip and this is the vehicles statistics. Bear in mind she is a month old
I will put up real life figures up tomorrow after I have filled her up to finalise the trip.
I got this sorted now.
This is the photo I wanted to upload before our road trip. This is my gearbox sump after 4500km and people ask me why I want to ged rid of the original oil so fast and here is the reason. Again I will do a gearbox service and post the results as you can see we did 4300km and all towing.
2717 mile, 210 US gallons, 7.3 gallons of DEF, LOL. Yup, I was raised in the old British system and have my truck set to US units. Never could wrap my head around metric and at 76 not gonna start now.
you guys dont calculate the DEF fluid? Its a running expense like fuel and if the consumption changes then something changed.
From what I’ve found most people don’t, just add a 2.5 gallon jug when the tank gets low. It’s incredibly difficult to determine DEF economy that way.
Personally I track it and only fill up at the pump.
As of my last DEF fillup I was at 22,436 miles, 1730.8 gallons of diesel, and 41.3 gallons of DEF.
aCar/Fuelly does a pretty good job calculating MPG with partial fills. I only every add a 2.5 gal jug at (usually) 1/4 tank.
I keep track of the amount I buy. Over a long period you get a pretty good idea of the number of miles you get out of a gallon. However short term calculations are probably not accurate. I have been starting to use the pumps since the boxes are a pain.
