My point is you are misusing this thread. This thread is all about frequent regen issues. Please read the title. You are not experiencing frequent regens and therefore your experience in trying to use a product to solve a problem you aren’t having is irrelevant and confusing to people who come here to solve the specific issue of frequent Regens.
Please find another place to talk about your feelings on the relative cost of lubricants.
I had frequent regens. It was a serious problem. Instead of trying to address it out of a bottle I stayed on top of it until the actual problems were fixed.
It would certainly serve members much better to post what others have had repaired so members can look at possible reasons why their trucks are doing frequent regens and repair them versus dumping a few ounces of fluid into their tanks thinking it fixes the issue.
Of course being an engineer I tend to find out the root cause of why my vehicles have problems and fix them.
In my case it appears, and I posted it, frequent regens were due to a faulty MAF sensor outputting incorrect parameters along with what may well have been a cracked DPF. The MAF may have contributed to the DPF failure plugging up but there was soot in the tailpipe which leads me to believe there was a crack or other fault in the DPF allowing some soot to pass through. Y43 hadn't been performed yet so there was no particulate matter sensor to indicate any issues.
Erroneous output from the IAT sensor or the MAP sensor on the engine could also lead to frequent regens. Incorrect fuel rail pressure or a leaking injector too. A faulty differential pressure sensor could also do this. Rarely, except on high mileage engines, oil getting past the rings or valve guides can cause it. Turbo shaft seal leaking is also possible. I've heard the AA air filters may cause this. I've looked at both the AA and AB and can't believe a clean AA filter causes regens but an AB with say 15k miles and dirty doesn't.
Too frequent regens is the symptom of a mechanical issue.
AlfaOBD is pretty handy used properly along with one of the Autel units such as the MS908II. They can help if your dealer claims there's no problems with data logging abilities. If your dealer can't do anything, dig out a few dollars and take it too a reputable independent shop if you think there's a problem with regen frequency.
I've been forced into replying to things that had nothing to do with my original post. The data is there, take it or leave it, I really don't care.
Fix the truck rather than masking issues. Would you mask faulty spark plugs or wires by buying a higher voltage coil or would you replace the plugs? The new coil may fix the problem for a bit and you'll swear it works, which it did, but it didn't fix anything.
With that I'm out.
