Johnny McGhee
The truck is a 2021 Dynamax Isata 5 class C motorhome. It weighs just under 20K and now has just over 7000 miles on it. The only suspension modifications are front air ride and front Rancho shocks, both installed by Dynamax.
What started out as a barely noticeable rattle in less than 1000 miles became a unbearably loud banging according to speed and tire pressure. Dodge said they couldn't find anything and no longer under warranty anyway. I realized with the speed of the rattle it was connected to the bounce of the front tires not the sway of the truck, the dip of road, or turning. I can lower the tire pressure from 80lbs to 60lbs and drop the rattle some, but the body roll now is dangerous.
I started with the sway bar grommets/bushings at the links, then the links themselves, then later in this process actually removed the sway bar and links completely and test drove. Rattle still there. I spent hours underneath with a rubber mallet and found some rattle in both front calipers so I removed them and greased the guide pins with no luck. Tightened all 6 body bushing bolts, all shock bolts, all eight of the four link bolts, and anything else I could find to put a wrench on. I found slack in both upper ball joints so I replaced both, slack is now gone rattle is still there. The slack in the upper ball joints was in and out, so i set up a dial indicator to measure vertical play, drivers side had none and passenger side had .006". No grease fitting on the lower joint. Turning the steering wheel hard and fast I found a rattle in both ends of the drag link bar, installed new bar but still rattles.
I'm getting ready for a cross country trip and really can't leave out with this going on.
Hopefully someone has seen this and has a direction to go from here.
