Truck typically regents every 200-300 miles. I’ll get several days with no movement of the dpf gauge then it’ll fill and go into regen over the next 3-4 trips. I poured a bottle in and refilled the tank with a high flow nozzle to mix it. The gauge was at 25% when I filled it. It went to 40 percent. Then stayed there. Then went down to 25 percent again. This morning it went down to the 12 percent range with essentially the same driving routine aside from a short 20 mile jaunt across town at freeway speed. It has never done that before. I’ve only used the initial 5000 mile treatment so far. And have only burned the first 1/4 tank worth of fuel.
With that in mind it has me leaning much more to fuel quality/injection issues causing the regen rates we are seeing.
