2019 Cummins 6.7 dually 3500 stalls on freeway and hard to start!
Joseph Mai
Hi all, my 2019 cummins 6.7 with 127,000 miles stalled a couple of times while driving within the past weeks. When I tried to start it, its very hard to start. It could be cranking for 5-7 seconds before it can start. This problem comes and goes. Also it idles pretty rough. Especially at 1200-1400 rpm truck vibrates a lot. After 1500 rpm then it’s smooth out again. Anyone ran into this issue? Do you know what it might be? It doesn’t throw any codes. Truck has been deleted. This problem happens before and after the deletion.
When was the fuel filters changed last
Have you had your CP4 high pressure fuel pump replaced under the Y78 recall?
Its more likely a failing lift pump or FCA vs a failing CP4 when the CP4 goes it goes it does not give intermittent issues
Where did you get your fuel filters?
Amazon has many counterfeit fuel filters that will cause issues.
