silver billet
There is so much talk about power off the line here. Are you guys really having trouble getting going? Are you really trying to rip off the line with 20k lb behind you? Sounds like a great way to mess up the 5er and everything in it!
I've never towed anything heavier than 20klb so is that just why I'm not complaining about power off the line?
No argument from me, that's why I've been saying the gear ratio is less important than many think it is.
I partly blame the J2807 standard for this, it exaggerates the differences in two otherwise identical trucks by several thousand pounds GCWR just due to how fast they can or cannot get off the line in first gear.
But in real life, that's far less of a problem. Almost nobody has trouble getting going, if they did they definitely wouldn't be able to pull at 60 either.
In real life, people want more power getting onto a freeway onramp (so city mph to freeway mph while already rolling quite fast), or passing a semi up a hill. And at that point your transmission is more than capable of putting your rpms where they need to be by downshifting, cancelling out the advantage of the rear axle - so only more engine torque/hp will help in these cases, hence the recommendation for the HO instead of the SO.
