2023/2024 Digital Cluster Upgrade?
Yours would be easy being a 23 already. You just need the cluster, custom adapter harness, and the left steering wheel switch with the menu pages button.
If you want the factory maps to display in the cluster, you need AlfaOBD, and your radio has to be a 12” or 8.4” with nav.
Hey do you guys know what’s the part number for the left tearing wheel switch ?? Thanks in advance
Thanks really appreciated !!
Does anyone know how to update the mileage after the cluster upgrade mine is a 2023 2500
Milage is at 0 I need to put the original miles any help will be much appreciated TIA
That’s strange that the non digital cluster equipped left wheel switch has the pages button on yours. This is a 2023 Laramie with the non digital:
But, if yours has it, that’s one less thing you need.
AlfaOBD would be needed for the swap because there’s a setting in the BCM that tells the radio to use the Ethernet block to send the maps to the cluster
How do you activate that setting with Alfa obd ??
Ecuconfig 3: Audio Steering Wheel Switch Configuration- Core Steering Wheel
Ecuconfig 3: Unique Core Steering Wheel- Yes
CustSetMenu 3: Album Art In Cluster- Yes
CustSetMenu 3: Audio Steering Wheel Controls on IPC- Yes
CustSetMenu 3: Twelve Inch Radio Present- Yes
CustSetMenu 3: Nav Map In Cluster- Yes
Thanks jimmy now last question can it be done from the android app or it has to be the windows version???
Hey jimmy do you know why all this lights and message appear on my cluster how can I get rid of them
Did you change your tire size? Connect to the engine controller and abs module and see what faults are stored.
Yup you right I change my tire size and put the wrong number and threw all those codes thanks
Not necessarily the wrong size, but you need to run the abs initialization after a tire size change.
Jimmy07, im new to this but i have a digital cluster coming with harness. 2023 Ram 2500. Is there a solution to the mileage and hours? There are so called people doing it but cant get any info on it.
