Really. Every time i would build one online it jumped it to push button. I know the build and price is not always accurate thoughFake news I have a level 2 t-man
I've tried to convince my wife of the small difference between 2500 & 3500 for quite some time and failed everytime lol.
That.Cummins vs Hemi comes down to use.
Absolutely. I, on the other side, enjoy the electronic helpers that make driving easier and more pleasurable.To each their own.
It’s become easy to ignore all the wacky stuff, it all drove me nuts at first…a lot of it can be turned off, she found out. If I don’t plug it in, my phone behaves normally.I had a truck with all of the options. Blind spot monitoring, adaptive cruise, lane change assist, auto high beams, rain sensing wipers, pano moonroof etc, etc. After a short time of ownership with that I decided never again. I can’t stand all of that stuff
The only things that I like for sure are cloth seats, heated seats and wheel, and I do like the 8” screen and wireless CarPlay. That’s why I bought a nicely optioned tradesman and added OEM heated seats and wheel myself and it cost my 1k. I know I’m the minority but I’m much happier with that than a truck with all that other stuff that I don’t want or need. To each their own.
Both come with the package, AFAIK.and *no* adaptive cruise control or lane assist
If you are going to tow a TT or 5th wheel I recommend buying an F250 or Chevy 2500. I own a 2024 RAM 2500 Laramie Night Edition. My Cargo Carrying Capacity is 2119lbs. Most all 5th wheels that are around 25-30' have a hitch/pin weight of 2000lbs or over. That means my wife, dog and I plus fuel couldn't be in the truck without exceeding the CCC. Yes I see RAM 2500's going down the road with huge 5th wheels in tow, however I guarantee they are grossly exceeding the truck's CCC. A person who stores his RAM 2500 attached to a 40' 5th wheel where I store my TT, is exceeding the truck's CCC by 600 lbs. I shake my head because my RAM 2500's rated TOWING CAPACITY is 20,000lbs, however that's not the CCC. When I see someone at a campground with a RAM 2500 and a huge 5th wheel or TT I ask them about weights. Not one person has talked about CCC. They all talk about Towing Capacity. F250's and Chevy 2500's have a CCC over 3000lbs.Currently in the market for a lightly used or new Ram 2500 limited and I'm a little confused on all the "options" you can select. I was curious what options people think are a "must have" with these trucks. Looking to keep the truck at least 10 years and currently only occasional towing is expected but we might opt to buy a travel trailer or something at some point depending on where life takes us... Please feel free to comment on my "must haves" below as well
My known must haves:
- Level 1 Equipment
- Night edition
- Anti spin diff
- Bed step (can I add this later?)
I'm upgrading from a 2004 ram 1500 with low miles
Edit:
I guess let me rephrase it.... I'm torn on the following items because I don't know what they do or if I'd really use them
- Aux switches prep (or the aux switches)
- Adaptive steering (probably not super useful for me)
- Towing (I'm confused on the below items and what the difference is)
-Wired tow camera
- Trailer Surround-view camera system
- tow mode digital rear-view mirror
- Tow Technology plus group
- Towing technology group
What does the self leveling suspension give you? Air ride or something else?
I’m in CA and the local CHPs main concern is that you are within driver license weight limits. They check your trailer gross weight and make sure your license is good for it. Don’t get me wrong if I was towing a fifth wheel or something like it all the time I’d recommend at minimum a 1 ton.GVWR is for marketing and meaningless number just about everywhere. Don’t exceed your axle ratings and call it good.
For example in Idaho the only place it’s mentioned in the statutes is in the glossary. There is no weight law that utilizes GVWR. Every state I’ve researched is similar.
Ram could, and should, up the GVWR of the 2500 without changing anything about the truck. They are simply trying to stay within the Class II vehicle market, but Ford and GM have made their 2500’s Class III which is good for most but also detrimental for some commercial application.
Sorry for the slow response but I was doing some more digging so the Limited level 1 appears to come with the digitial rearview mirror, adaptive steering, and trailer reverse guidance. So to get the Tow Mode DRVM group I would just but the camera and not the package correct? Is the Tow Tech Group plus worth it? I'm thinking I'll only be doing occasional towing and have never felt I had issues with blind spots before.For me it’s a strong dislike of the adaptive steering that cannot be turned off.
I wouldn’t mind adaptive cruise control, but wish Ram would put the camera in a different location. It’s large and semi-obtrusive.
I haven’t found a need for BSM in these trucks. It does come in handy on vehicles with smaller mirrors.
6 switches on the center stack that can be utilized to add aux electrical systems. For example I have backup lights, an air compressor, a winch solenoid, and a trailer tpms booster on mine.
Adds an electric motor to the power steering. It can be ordered separate or with the safety group. The safety group uses it for lane keep assist.
I suggest driving one with it before you order to see if you like the feel.
The Digital Rear View Mirror has a camera in the CHMSL and a plug on the rear bumper for an extra camera. This is that extra camera. It's nearly impossible to find after you place the order, so if you get the DRVM order this.
A 4 camera system that you install on a trailer to have a 360° trailer camera view. You need the truck 360° camera for this feature to be active.
DRVW with the tow-mode camera included.
DRVM 3.0 with extra side cameras that show up on the DRVM. It also includes trailer steering control for reverse. Aux switches are not compatible with this option.
Truck 360° camera, and cargo view camera.
On the 2500 it's 100% air ride. One the 3500 it's a supplemental airbag setup on softer leaves for better ride and handlig, both loaded and empty.
So I think I'm just deciding on the following
- Trailer surround (seems like it could possibly be added later)
- TTPMS (Seems like it could be added later but maybe harder)
Thanks the problem is "want" vs "need" is the big question... right now we don't own a trailer and as much as I'd love to in like 5 years there is no guarantee we will. I also like to keep vehicles for a long time (current truck I've owned for 16 years)Yes, the wired tow-mode camera would need to be ordered separately.
I don’t think so, I like aux switches and you can’t have the trailer reverse steering with aux switches. I don’t like trailer reverse steering anyhow.
Believe so, but it may take hardware and software changes.
Yes, I don’t believe it’s too bad to add but will also take hardware and software changes.
My 0.02 is that if you might want it down the road just order it, it’s easier.
Blind spot monitoring, adaptive cruise, and auto high beams are probably my favorite features on our 2022 Limited. They make the drive safer with no downside - what’s not to like? I really like the steering assist on our Acura RDX, but it is not well implemented on our RAM. If it was sensitive enough to keep the truck centered between the lane lines without hunting, it would be great, especially pulling a 44 ft. 5ver with a dually. But like everything else here, you can turn it off if you don’t like it.I had a truck with all of the options. Blind spot monitoring, adaptive cruise, lane change assist, auto high beams, rain sensing wipers, pano moonroof etc, etc. After a short time of ownership with that I decided never again. I can’t stand all of that stuff
The adaptive cruise item has been around for a very long time our 2012 durango has the same issue with braking but I suppose it's perhaps a safety thing.Blind spot monitoring, adaptive cruise, and auto high beams are probably my favorite features on our 2022 Limited. They make the drive safer with no downside - what’s not to like? I really like the steering assist on our Acura RDX, but it is not well implemented on our RAM. If it was sensitive enough to keep the truck centered between the lane lines without hunting, it would be great, especially pulling a 44 ft. 5ver with a dually. But like everything else here, you can turn it off if you don’t like it.
The adaptive cruise on our Ram has one shortcoming - it slows down if a vehicle changes into your lane within the set gap. That is a software issue. It should back off of the gas until the gap is restored but not use the brakes. Unfortunately, most companies, off all types of products, seem to forget about fixing issues on past models. Once it’s sold, it’s “not our problem”.
