Onboard Air
Kcarter2088
Hi guys. I want to install a compressor. Was thinking an ARB. What do you guys recommend? Where do you recommend to mount it? Thx for your help in advance. I have a 3500 HO Diesel Mega Cab. Limited.
I have a ViAir 400C mounted under my bed, to the bed on the drivers side forward of the tire, and a chuck in the bed near the drivers aft cleat. The 400C has been a great pump for flats, airing up after driving back roads, etc.
Thx for the info. Do you have an air tank?
same place i mounted mine for my air bags.
Can you post some pics of the installed compressor and chuck? Thanks
Double Viar with tank on passenger frame rail with custom mounts. Lost a little bit of depth on storage bin in floor.Single pod display in cab for air bags and tank pressure. Used most of the riv-nut holes on that rail to avoid drilling frame.8C3FA5B0-76E9-418E-9644-A669AEF6EA78.jpegBB2FD3ED-9841-4EB7-B35A-D6CA5BEC7A6E.jpeg012B1717-1962-4997-9D4C-8349527964F1.jpeg
I had a dual ARB compressor I took out of my Jeep in favor of a mini York engine driven compressor. So I decided I wanted to mount the ARB in my truck. Found a mount from 813 Fabrication that was designed for a Jeep Gladiator that I slightly modified to work for my situation. I wanted to mount it in the bed to keep it covered from the elements under my bed cover. Also needed to clear when our camper was loaded. I had to bend the mounting tabs, 3d print spacers and cut a hole in the top for it to work the way I needed. I do have a tank I will install at some point. I put a chuck under the bumper so I could still get air if camper was on. Has come in handy having air available. For wiring, I got a 17' harness extension from Expedition Essentials and ran it to the engine compartment. It is for a Toyota Tacoma, but worked great for me. I wired it to one of the Aux switches on the dash for activation and the pump wires to the driver side battery.
