I’d love a 37x11.5R17 in a MT BB AT on stock rims but I believe the only availability in that size is a Nitto Recon. I do want a 3MPSF which the Recon is not.You can run 37s on stock suspension no problem, it's the stock wheel offset that is the challenge. The OEM wheel offset is somewhere in the +44mm to +54mm range, which means that when you put on 37s (which generally are 12.5 to 13.5 wide) you're extending that in even further. The recommended wheel offset is +18mm to +25mm.
If you're dead set on running the OEM wheels you can either run a narrow 37" tire (I believe mickey makes a 10-11" 37?), you can change the swaybar to a Thuren high clearance swaybar and Thuren/Carli/FirchFab radius arms, or you can deal with the rubbing and potentially lose a little turning radius.
How hard is it to change the wheel offset?You can run 37s on stock suspension no problem, it's the stock wheel offset that is the challenge. The OEM wheel offset is somewhere in the +44mm to +54mm range, which means that when you put on 37s (which generally are 12.5 to 13.5 wide) you're extending that in even further. The recommended wheel offset is +18mm to +25mm.
I don't know if you live in an area where a 3PMSF is a requirement, but those recons look like they would do decent in the snow, just going by their lug spacing. Perhaps look into some reviews if having the icon isn't a hard requirement?I’d love a 37x11.5R17 in a MT BB AT on stock rims but I believe the only availability in that size is a Nitto Recon. I do want a 3MPSF which the Recon is not.
You don't change wheel offset, you just buy new wheels. In order to get the correct offset on the OEM wheels to not need high clearance radius arms and swaybar, you'd have to run something like a 0.75" spacer, which is not something I'd recommend at all as you're just losing thread engagement on your hubs.How hard is it to change the wheel offset?
Not a requirement here in the Cdn Rockies but given I ran dedicated winter tires 6+ months of the year on past trucks I feel 3PMSF is a minimum threshold for a year-round tire. Research on the Recon doesn’t uncover anyone raving about snow/ice performance and just visually you can see it has noticeably less siping than say a Baja Boss, Wildpeak or KO2. I think I will take this in steps: replace the OEM Duratracs with 35” 3PMSF A/T’s (MTBB’s or Wildpeaks), see how they work for my purposes (everything from black ice to highway towing to annual Moab trip) and, then when they are due for replacement, make a decision on 37x12.5’s + new rims with the needed offset to run those tires.I don't know if you live in an area where a 3PMSF is a requirement, but those recons look like they would do decent in the snow, just going by their lug spacing. Perhaps look into some reviews if having the icon isn't a hard requirement?
My brother has the Baja boss ats in a 37 on AEV saltas (+27 offset I believe) and stock suspension on his 22 power wagon and had no rubbing issues whatsoever. Truck is an absolute tank in the snow on that setup.Not a requirement here in the Cdn Rockies but given I ran dedicated winter tires 6+ months of the year on past trucks I feel 3PMSF is a minimum threshold for a year-round tire. Research on the Recon doesn’t uncover anyone raving about snow/ice performance and just visually you can see it has noticeably less siping than say a Baja Boss, Wildpeak or KO2. I think I will take this in steps: replace the OEM Duratracs with 35” 3PMSF A/T’s (MTBB’s or Wildpeaks), see how they work for my purposes (everything from black ice to highway towing to annual Moab trip) and, then when they are due for replacement, make a decision on 37x12.5’s + new rims with the needed offset to run those tires.
Picsim rocking a set of 37 x 12.5 x 17 Baja Boss's and i love them! i got the CJC method exclusive rims and i have a TINY bit of rub on full lock on inclines; but other than that theyre amazing! i am considering going to 38 x 13.5's
For the guys running the Mickey Thompson Baja Boss AT tires in 37", what load rating are you running? I can only find 37's with a "D" load rating.
That's what I was guessing. I just don't have it in me to run anything bigger than an 18" rim. 35's it is!!!I don't think they make the "E" in the taller sidewalls. If you get a 20" rim you can get the 37" in E, though.
I'm now very interested in your thread. I'm hoping someone else has tried the 37's on -12 offsets to tell me what to watch out for.Anyone have 37” bajas on their stock suspension power wagon?
I think these will be my next shoe change and i’m teetering between 35’s and 37’s
2022 PW
