Is it just camera angle or are you sitting a little nose high?
Installed air bags over the weekend with the compressor and wireless setup. the check valve was cracked either from the factory or i did it when i tightened. i don't know so have to order/get it replaced. removed that and filled it off the bumper valve and i apparently have a slow leak somewhere. will trace it out once i get the check valve back in.
Bummer on the leaks. What bag setup?
What are the lines? Poly with push lock fittings?
Sent from me
Glad I could help!You just reminded me to lower my rears back down to 45
I have been fortunate enough the have never used them on my truck, but I have used them several times the recover other vehicles with good success. I will say though, the lower amount of tread on the tire lowers how effective the boards can be.Have you ever had success with the recovery mats? I find they are a good idea with minimal results
How did you get video to play on that bottom screen?Finished the Air bag stuff last night. pulled every line and recut and replaced. flipped my compressor around and bolted it in more securely cause apparently maryland roads and self tappers dont mix. reran my air line for the filter to a better spot. discovered the bumper mounted air fill line was being harrased by my spare tire which was producing a large leak so had to look at it and go stop it. it stopped.
the app is cool, don't even need it on my phone. just added it to the radio i installed last week and I can monitor it when I'm not watching tv lol.
Next up, new brakes, possibly rotors cause might as well. gender fluid change, tcase fluid change, and at least rear diff fluid change.
For those that tow heavy, what other things can i do to make towing 13000 lbs better. mainly suspension and or just over all safety. i do fine but id like to make sure that not only the gf and dogs are living the best life, but i am as well.
View attachment 71302View attachment 71303View attachment 71304
Thats cool. Looks just like the factory 12" radio display.its not a ram radio. its aftermarket. so i can pretty much do what you can on a standard android tablet.
theres threads on here i think on it.Thats cool. Looks just like the factory 12" radio display.
