Did RamTrucks.com remove the VIN lookup tool?
I'm researching Ram 3500's for a potential purchase and wanted to check payload ballpark on upper trims. A few weeks ago I found this through a google search, and the link worked. Now, the URL hits that "you've come to the end of the road" error that the Ram website gives for any invalid URL.
Has anyone found an alternate tool or the new URL? At least a few weeks ago, it seemed to have no navigable path to get there from the Ram website itself, you had to just "know" or have it bookmarked from back in the day (2022 apparently).
Thanks!
-T
I've found mixed success in using https://windowstickerlookup.com/ in addition to googling "{year} ram 3500 payload numbers" and matching the window sticker details with the data sheet from Ram.
It comes and goes. The only thing I can figure is that with the SAE standards having a dynamic quality to them, that can change what the numbers are when, for example there is an update in the standards, or a clarification is provided by the SAE. I'm surprised there isn't some kind of disclaimer when the thing does work to be honest. But over time mine has varied by like 200 lbs on both payload and max tow. The last time I used it a couple months ago my payload went up 200 lbs from like 3080 to 3200 and change... Same for the 15K max tow. It's nice when it works but the charts still out there will also get you in the ballpark.
It’s likely computer glitches not SAE changes.
Your payload is GVWR minus curb weight, so that’s not going to change.
Nerd warning...
It is exactly "computer glitches" or rather bad programming. If pull up the Developer Tools built into your browser you will find that the in the backend RAM's towing guide (click "Look up my vehicle") is returning an error. After you enter your VIN and click "Find" it wants to call: https://www.ram.com/towingws/TowingServlet?vin=YOUR_VIN_HERE&serviceType=json&action=TOWINGINFOBYVIN , run that URL directly in your browser and you get:
{"data":{"status":"failure","status_code":"ERR_105","status_desc":"ServiceType is not valid. It should be 'XML\/JSON'."}}
Somewhere in the corporate offices of FCA/Chrysler or some contracted vendor, a software engineer isn't doing good job of QA'ing their code. He probably said something to the effect:
Works on my machine. Ship it!
After a bit of playing around, I found that this URL below may work in your browser to return you a raw data JSON object with your vehicle data. Swap in your VIN. Note, the forum software keeps visually shortening this URL, you will have to right click and "Copy Link Address".
My Result:
Might be a bit more readable in XML format depending on your browser:
Chrome here:
Very important note here for those not as well versed in this data, Base Curb Weight is not YOUR curb wieght, it is the estimated curb weight of a stripped, base model truck. Calculate your curb weight as
GVWR (10k for me) - max_payload (2755 for me) = 7245 factory (as shipped) curb weight
And as always, weigh your vehicle as you drive it (regularly loaded with all normal passengers) to get your most current numbers.
Nerd warning...
After a bit of playing around, I found that this URL may work in your browser to return you a raw data JSON object with your vehicle data. Swap in your VIN
My Result:
Chrome here:
Good info but they still have some back end data/database issue (missing) or code as well.
I'm seeing a bunch of CORS errors so there's that too.
That very first link you show only shows MY 2018. 2017.
What a hot mess.
My 2020 "lookup"
data>
<script/>
<status>failure</status>
<status_code>ERR_104</status_code>
<status_desc>Model Year outside supported range.</status_desc>
</data>
What a hot mess.
My 2020 "lookup"
data>
<script/>
</data>
Try this URL (swap VIN), what does it show you? I have a 2023
This worked for me, and I have a 2024 with a window sticker available, but truck still at Saltillo plant waiting for a train. Do we know the difference between mpi_max_payload and max_payload? The mpi one is roughly 230# more in my case, but already being 3699# vs 3930# it is kind of noise. If I take the GVWR minus the "base curb weight" I get the higher mpi payload. Perhaps the 230# is with full fuel (31 gallons diesel in my case should be ~240#)
MPI is base model (stripped) truck. The less advantageous number is your truck's number "as built". Those cool extras and luxury features we like to have add weight to the vehicle and subtract from payload and towing.
My '23 sat at the Saltillo plant for ~4 months waiting to ship last year. I hope you don't have to wait as long as I did.
Right on. I guess since my F150 had about 600# of options from the base, I thought 230# seemed small for this beast. But really I only got sunroof, tail step, clearance lamps and longhorn package above the base spec'd 4x4 CCSB+Rambox. 230# seems like a bargain for those options.
By the way, GREAT find digging into this. I have been wanting to preview my payload since I ordered and I bookmarked the VIN towing tool to see if it ever came back occasionally. Nice work!
I glad it worked for you, I wish it worked for all, even more so that RAM's site would "just work" like it should.
My '23 sat at the Satillo plant for ~4 months waiting to ship last year. I hope you don't have to wait as long as I did.
I feel your pain! They are shipping EXTREMELY quickly currently, some were built after mine and have already shipped. It has only been 3.5 weeks sitting for me currently but painful seeing others that sat less than 1 week at the plant and jumped ahead of me.
My F150 took 7 months and our Maverick took 13 months. Good things come to those who wait, but it is HARD when this excited...
Could someone decipher the results of my vin? When using the above link, I get:
success3C6UR5SL8RG2793991957.392050.001957.3919348.4219200.019488.391000027531.00600060407807.58
I guess there becomes a time when that data is no longer supported, haha. My year is now outside the range of that tool. Kinda surprising as I can't imagine it's a huge table to keep.
