John Jensen
My towing dropped from 14,906 to 14,548.On a positive note my towing number increased by 92 pounds from 16620 to 16713 pounds.
I also noticed a buddy’s 2018 HO went up 247 pounds.
So its not all doom and gloom.
Sounds like a reason to upgrade.Mine went down by 7lbs.
Sadly that link is only good for 5 years. I used it to validate, but I am looking at 6-7 year old dinosaurs!Thanks for the update, I had that same link book marked and it quit working. Strangely, still can’t get to it if you just go to Ram.com and “look” for it………..
Those numbers should be accurate as it came from factory.Man, Ram is having struggles... I put in my VIN and it came back as a Lone Star Crew Cab when my truck is a Big Horn crew cab. It is a Hemi 4x4 with the 6'4" box., however I have the offroad package as well, so do these numbers reflect that too?? Logged into my owners dashboard, and it doesn't tell me the model at all anymore like it did before. Just tells me I have a 2500 Ram Truck. lol
I'm not sure if I should trust these numbers or not?
Just checked mine and the payload is down 75lbs from what the sticker on the door says.
Whatever data is created and used to print the door sticker is the same data that should be used to create the website info. That is certainly not rocket surgery, and is done millions of times a day in other industries. Ram has a poor reputation right now with their electronics and technology... this kind of stuff doesn't help.Despite many ridiculous things in modern society, we are still a ways out from a website trumping a door sticker. Not that 75lbs is a big deal, but rest assured you are safe at the what is printed on the truck.
Even then, GVWR isn’t legally binding in most states. Axle weight ratings and tire ratings are.
The Society of Automotive Engineers (SAE) "revised" the standard in 2020. Thus anything "figured" prior to that change might not be accurate as of the change. Most of the changes in the standard that ALL major manufacturers use were in how you determined the ratings by testing and clarifications. Could be that the manufacturers learned how to game the standards just a bit to get higher numbers and once the Society of Engineers saw what they were doing, they fixed that thereby making the posting of numbers "prior" to 2021 "problematic." Remember that members of the "society" are the same engineers that make the cars. Within a given manufacturer there is ALWAYS a dynamic between the engineers, bean counters and marketing pukes. That and lawsuits is why the SAE finally got the manufacturers to accept the standard in 2015. Prior to that, the Marketing pukes ran the show and told consumers they could tow most anything up to the Empire State Building with an SUV. You could be seeing some of that going on in a simple thing like not showing numbers prior to a change in the SAE standard. Politics within corporations using consumer safety as a lever. When FCA sold to Stellantis, there was a change in corporate culture and likely disarray within the corporation as a whole as they transitioned from one management structure to another. That is when politics at lower levels often play out. The Engineers or Marketing pukes or bean counters get the upper hand in a given situation and make a point to the others. If you look at Iacocca at Ford, and why he left, you can read about these kinds of human socio-political dynamics. The bean counters won that "battle" and we got the Mustang II. But that failed so horribly that the engineers got back and at the worst, the engineers and the marketing pukes worked together, until the marketing pukes over stepped their bounds in their zeal to sell cars... This kind of thing is always going on... Subaru was a company run by engineers. Their cars were NOTED for the engineering and quality. Then they hired a Marketing puke as a CEO. He started selling cars hand over fist whereas the engineers couldn't sell them, but at the expense of engineering. I had a gen of the Forester when this happened. So, I had an early gen and then a .5 version. They changed the springs and the wheel to wheel turning radius on the steering and the shift points. It was all done by the marketing pukes to appeal to a certain demographic... Soccer Moms basically. I had a former Subaru Engineer tell me this... My 2004 Forester towed a 1900 lb pop up camper like a beast. My 2007? Not so much. I remember going up the IKE with the trailer in the 2004 and it just went at 45mph. I did it in the 2007 and the car was like Excuse me? at 35 and hurting... So, I moved one while the soccer moms bought them hand over fist and still are...Morning,
Unless I'm missing it somewhere or completely missed that there was information this was being removed, but I can't find on the Ramtrucks site under "towing and Capability" the area where you can put a VIN in and see the payload, max tow ect. Anyone else notice this? or was this out there as being removed at some point? Certainly not the end of the world but it was nice while looking at new trucks. Thanks.
