Owners with Regeneration Frequency Issues:
I’m going to start compiling data on the trucks experiencing regeneration frequency problems. If your 2019+ Cummins powered Ram HD is regenerating more frequently than you believe it should, or has demonstrated trouble code P2459, I’d like to get data from you.
Based on the lessons learned from my Aisin K1 snap ring spreadsheet, I’m going to attempt to go about this a different way. I’ll be using a Google online form. You fill it out and submit it electronically on your mobile device or computer and I’ll be able to get your information that way. This should make it a more streamlined process.
I would recommend opening the form, reviewing the info, and making sure you have all the data prior to starting the form. You won’t be able to go back and make changes once it is submitted. The form will generate the information that will ultimately be compiled on the publicly viewed spreadsheet, which I will post a link to once we start getting the info in.
Here is a link to the data submission form:
https://forms.gle/gbVRwtFzhNPVZ2mS6
Edit 9/15/23: Finally got the first data from the responses to the submission form uploaded to the crowd sourced tracking spreadsheet. The spreadsheet is set up for public viewing. Please follow this link to see the sheet:
https://docs.google.com/spreadsheets/d/14bISF2nKiXzO7QWlsHJHS6Z7R_HaNgsfyfXCy_z7SEM/edit?usp=sharing
