What did I do to my ram today. Backed it out of the driveway twice. Once so the mow crew didn't fling junk at it and once so the weed eat crew not to chip it. Rough life I know. While i was driving around the block, i changed 2 displays on my evic screen. Top rt & lt. I had compass and weather temp, but they are redundant as they are on the uconnect screen. The only thing i didn't have on my evic screen was boost psi and Jake psi, so there they go. Now the only thing I have to scroll for is truck and trailer tire psi.
Work... work...
Then play...
Applied ceramic coating on leather seats, steering and door trim.
First time doing it.
Turn out it is very easy to do.
send us a pick
You mind sharing which product you used for that? Thanks!
Sure.
First I used CarPro Inside to clean and remove any oil residue, even if truck is just a week old or so.
Then I applied CarPro C.Quartz Leather Coating.
Note: the 30ml bottle was just enough to do front with two coats. I ordered a second one to do rear seats. I recommend ordering a 50ml or 2x 30ml bottles to do the truck.
I basically duplicated the suggested recipe found here:
As stated, very easy to do!
Nothing to see! That's the point. Protection without changing appearance.
Ahhhhh, gotcha, I would of assumed the ceramic would of really made them shine, shows yah how much I know about that stuff
Was busy over the weekend.. Put the grill back together, installed an xpel kit on the front end, blacked out most of the chrome with black vinyl and swapped on new emblems
Gaaaaaassssseeeeed on ittttttttt! 300 miles through Seattle and Portland in 4 hrs with a doggie potty brake at the rest area.
That’s not bad! One time it took me 8 hours to go from Bellingham to Olympia the traffic was so bad! Washington drivers suck!
Oh, believe me traffic sucked bad, and there rds suck even worse, lots of chucking on that wintered concrete. I waited until after morning work traffic, but I had to pretty much stay in the hammer ln and a few hov ln maneuvers to pass between toll cameras. Every time I glanced at the big screen , it looked like an octopus of tangled up rds
Impressive for sure. That wasn't possible pre-covid unless you were doing it between 1 and 5 AM.
OA
