JRGPHOTOGRAPHY
Update: The dealer did a cold start and there is still a slight sound so I am not even sure the cam and lifter replacement fixed the issue SMH
So, at the end of my debacle with my 6.4l I actually had the truck back with the brand new motor in it for a few weeks before my surrender. I will note that when the dealer fired it up for the first time on cold start it very briefly made the knock on start up. After that the new motor sounded like I would expect a motor to sound. Of course like I said before, lifter replacement didn’t help a thing, I will note that they did not replace the cam, just the lifters. Was the noise after cam and lifter replacement made on initial startup or is it every morning at cold startup like before the “fix”?Update: The dealer did a cold start and there is still a slight sound so I am not even sure the cam and lifter replacement fixed the issue SMH ![]()
It made the sound again after the cam and lifter replacement. I didn’t hear it but the tech said it wasn’t as loud but he could still hear it. He said he would look further into it. It’s frustrating I just want to trade it in for a Cummins already lolSo, at the end of my debacle with my 6.4l I actually had the truck back with the brand new motor in it for a few weeks before my surrender. I will note that when the dealer fired it up for the first time on cold start it very briefly made the knock on start up. After that the new motor sounded like I would expect a motor to sound. Of course like I said before, lifter replacement didn’t help a thing, I will note that they did not replace the cam, just the lifters. Was the noise after cam and lifter replacement made on initial startup or is it every morning at cold startup like before the “fix”?
Above the catalytic converter which is factory but I was over the dealership lagging so I just welded it up at home.Where is that bracket located at?
I was looking at mine today while changing the oil and it maybe cracked too. When I hit the tube that exits the drivers side exhaust manifold it rattles and it seems to be from the same location as yours.Above the catalytic converter which is factory but I was over the dealership lagging so I just welded it up at home.
Ya it seems like a weak point this is a pic of where I fixed it.I was looking at mine today while changing the oil and it maybe cracked too. When I hit the tube that exits the drivers side exhaust manifold it rattles and it seems to be from the same location as yours.
No picture came through.Ya it seems like a weak point this is a pic of where I fixed it.
