2022 2500 Big Horn Truck Bed Holes
MarkCO1
Colorado
A is 7pin trailer plug hole, b is the switch for the bed lights cdc is for the for mentioned lights. B is for your imagination to run wild
B is the switch for the bed lights.
I suspect 'E' may have something to do with the manufacturing process and have no function at all. I've got that empty hole on the driver and passenger side, and at the front, there are corresponding holes as well, but they are both plugged with bed liner over the plugs.
I’m thinking B might be a possible correction location for on board air for me. Easy access, protected, but far from front tires on truck.
Go go gadget search function to find more.
Slightly off topic but does anyone know where to get the factory 7way/12pin for the bedside that comes with the factory tow prep? I’ve looked all over and can’t find it or haven’t found the magical name Ram has it labeled in the parts catalog.
A is the in-bed power. B is the bed LED switch.
7-pin trailer/12-pin camera is to the left of that as shown in wrvond pic.
When I did the puck install and added the 7 way I bought a Curt plug and play. It came with a 90 degree plug for the limited space in the bed/rear quarter. It runs down and piggybacks into the bumper plug. Works great.
Sent from me
Amazon. Or any trailer accessories whop will have it and would install it too and will be cheaper than ordering OEM
Anyone have the Curt part numbers or link? I am going to need that eventually as well.
Well not sure how to efficiently tag everyone but I already have a 7way to run like I had on my ‘21, got it from Etrailer. I was just curious if the factory plugs/plate was available anywhere, I don’t have any use for the 12 pin at the moment but wouldn’t mind prepping the bed connection while I’m doing all this work (on the bumper I’ve got the 7way and 12 pin, no 4way).
