@williamfr if you want to know how your truck will set then get out a tape measure. Measure from a fixed point on the wheel to the fender, not from the ground. I like the lip between the center cap and wheel. Then look at the difference. Subtract 1” from the rear for alt ride height.
I just went out and measured mine again.
Front: 22 3/4”
Rear: 23 3/4”
That’s in normal, so in alt I’m dead level unless I have a lot of tongue weight on a bumper pull.
You can see that I’d still have a nice rake in normal with the 0.5” springs but would be nose high in alt with them.
If I really wanted to level the truck I’d do the 1.75” thuren level kit at 1” rear block with 1” rear spacers and then adjust the sensors to have a 1” rake in normal. That would preform well and keep the truck from being nose high when loaded. I seriously considered this route, but don’t want to have to lift my 5th wheel anymore than I already have.
For reference this is alt ride height with about 6,500lbs on the rear axle, 5,300lbs on the front axle, and ~1,300-1,500lbs of tongue weight. With 0.5” level springs it would be nose high and look overloaded.
