NO LONGER AVAILABLE: Looking for a Part Number? Must provide VIN (only up to model year 2020 at this time)
Status
Not open for further replies.
I can query for '21, but not filter the parts by VIN...I've attached a few parts groups that will hopefully help you out. Just keep in mind to check the sales codes since I couldn't filter them.
Thank you. I could not find the diagram in those attachments that depicts the flaps. I appreciate the effort and those documents. I will file them away.
Question about running board parts.
In the standard diagram, item 2 (electric) has a breakdown of all parts including the end caps. Items 3 and 4 they don't have a part breakdown. I really need an end cap but can only see a listing for the full unit. Does Mopar really not sell just the end caps for the wheel to wheel running boards? I don't think they are the same as the electric units.
Thanks!
Thanks!
Here are all of the part numbers they have listed for the running boards & side steps. If you can't find the part here, they probably don't sell it by itself. If you can't find a suitable off-the-shelf substitute, I'd find someone with a 3D printer and see if they can make one for you. I'm assuming the endcap is made of ABS, put I'm sure PLA (a more common 3D printer filament choice) would work also. There are places out there that will 3D print a part for you, but you would have to send them a CAD file. Fusion 360 is a good software choice (it's free and good), but there is a learning curve. If you don't plan on designing another thing again, you can take measurements with a caliper with what you want to duplicate and check out Tinkercad. It's a free web-based CAD platform that is pretty easy to use.
Yep, thats the diagram I was looking at. Odd thing to not sell considering how easy they pop off. But thanks for confirming. It's a pretty fancy chrome plastic part. With enough work could make one but will probably try to find a used piece somewhere. It's not one of those super critical things, but would be nice to have.
Thanks!
Hey Im changing my megacab to night edition from chrome (exterior items) and I think I have all my part numbers down except for mirrors and rear tailgate. I have a 2022 2500 Laramie (no 360), mirror not power folding, no power smaller blindspot mirror, heated, power adjust, puddle light
Tailgate handle On the tailgate its a led hitch light?
Ive looked through the thread before asking but any help is appreciated. Heres my current list and some shared vins of what I think will work;
Headlights: 68360178ac and 68360179ac
(1) Grille Inserts: 6nb35tzzab
(1) Ram letters: 68358570aa
(2) Cummins Badges: 68358494aa
Hood Emblems: 68362211ac and 68362212ac
Tailtlight W/o sensors: right- 68361718AD
Tailtlight W/o sensors:Left- 68361719AD
MIRRORS USE this VIN?
3C6UR5FJ4KG595395
DOOR HANDLES USE this VIN
3C6UR5NL3NG381392
Below are part numbers I saw on here
1UJ81LAUAI - FRONT/LEFT [PAU], [MNK] [GXD] = GRANITE CRYSTAL METALLIC, BODY COLOR DOOR HANDLES, REMOTE PROXIMITY KEYLESS ENTRY
1UJ86LAUAI - FRONT/RIGHT [PAU], [MNK] [GXD] = GRANITE CRYSTAL METALLIC, BODY COLOR DOOR HANDLES, REMOTE PROXIMITY KEYLESS ENTRY
1GH18LAUAF - REAR/RIGHT [PAU], [MNK] = GRANITE CRYSTAL METALLIC, BODY COLOR DOOR HANDLES
1GH19LAUAF - REAR/LEFT [PAU], [MNK] = GRANITE CRYSTAL METALLIC, BODY COLOR DOOR HANDLES
3C6UR5FJ4KG595395
3C6UR5NL3NG381392
I'm out of town right now, but I'll be back this weekend and will check it out.
3C6UR5FJ4KG595395
3C6UR5NL3NG381392
The second VIN you included is a MY2022, I only have up to 2020 and a few early 2021s. Hopefully you can look through the attached files and use the sales codes to verify what you've already found. If there is anything I misunderstood and you need me to recheck, let me know (make sure it's a 2020 or older VIN though).
Thank you I appreciate but Im a little lost in the pages of pages of parts numbers lol. I guess I'll try to make sense of it all. Thank you
If it becomes too much to go through, find a 2019-2020 that has the exact parts your looking for and let me know. That way I can query that truck and filter out all of the parts not used on that particular truck.
Sure, what are you looking for?
Looking for part numbers for this center console, (see photo) and part numbers for my current upfitter switch that has the tow/haul and exhaust brake (see photo) and one with the 5 buttons on it with the tow/haul and exhaust brake. I have a 2019 Ram 3500 Tradesman drw vin# 3c63rrglxkg578491. Thanks in advance.
Attached is the switch bank for your VIN. Also, a breakdown of the different switches is here and information on the console pictured can be found here. If you need more info than what's in that thread, give me a VIN that has the part you're looking for and I can check it out.
That's not an "upfitter switch." That's the standard piano key buttons.
Are you looking for the exact replacement, or the AUX Upfitter switch panel to match, as in you're doing a DIY Aux switch add on?
Thanks.
Yes to your question, DIY Aux switch add on. Be able to have the 2 switches for my options-Tow/Haul and Exhaust Brake, then the 5 switched/buttons under it to add accessories.
I found a Ram part number-68476026ab. My vin is 3c63rrglxkg578491. is this compatable for my 2019 Tradesman 3500?
Status
