Also the truck was delivered 5 weeks ago
I apologize, the process I gave you is for Ram's spec charts but wasn't exact. Try this:
Man I appreciate your help but neither really worked. The first link only lists for an SLT Megacab and I have a Laramie with options. So it is probably close for payload but not exact because I don't know the weight of my options.I apologize, the process I gave you is for Ram's spec charts but wasn't exact. Try this:
then select year/select model/select technical information/ select "base weights/cvw/payloads/trailer towing"/select model![]()
Ram Trucks Body Builder Guide - Upfit Your Truck
Ram Trucks Body Builder's Guide has information you need to upfit your truck. Explore the Body Builder Guide for dimensions, electrical & technical guides.www.ramtrucks.com
Here is the URL for specific data
Ram Towing Capacity | Towing & Payload Capacity Guide
Explore the Ram Trucks towing & payload capacity guide. Find information like Ram 1500 towing capacity, Ram 2500 towing capacity, payload specs & more here.www.ramtrucks.com
Bummer. Both sites work for me. Wonder why they don't work for you?Man I appreciate your help but neither really worked. The first link only lists for an SLT Megacab and I have a Laramie with options. So it is probably close for payload but not exact because I don't know the weight of my options.
The second link still says no VIN information available.
Since you have your truck just look at the loading sticker in the driver's door jamb. It has all of the relevant information there, and is the only "legal" source of truth. The online tool is really most useful for comparing trucks that you're looking at online.Man I appreciate your help but neither really worked. The first link only lists for an SLT Megacab and I have a Laramie with options. So it is probably close for payload but not exact because I don't know the weight of my options.
All but towing capacitySince you have your truck just look at the loading sticker in the driver's door jamb. It has all of the relevant information there, and is the only "legal" source of truth. The online tool is really most useful for comparing trucks that you're looking at online.
Copying and pastingUse that chart for GCWR as it won't change with trim/options (other than power train options).
Then use the door sticker cargo to determine your curb weight (GVWR minus cargo capacity). You can then use the notes at the bottom of the tow charts to determine max tow rating (passenger weight, accessory weight, hitch weight, etc).
That's all the website does for you.
Are you use the VIN isn't being fat fingered?
Oh silly silly spammer/BOT.I just bought a new car. I want to know more about using a vin lookup tool. Basically, I want to install it. So that I can easily track my car location if needed. Which one are you using right now? If this one for free or paid?
https://www.ramtrucks.com/towing/towing-guide.html/vin-lookup#/landing/bytowingThe link for the towing capacity worked for me the other day - now I am getting this as well:
Im getting the same result...no result.The link for the towing capacity worked for me the other day - now I am getting this as well:
That's the link that's not working now
Good thing I took a screen shot when it worked a week ago.Im getting the same result...no result.
If that’s the case i will be competing with honda crvs for payload capacity.The towing VIN lookup is very hit or miss, it's been that way for 2 years now.
Maybe they're lowering everyone's payload and towing again.
Yes, worked for me too.Today it worked. I am wondering if it just glitches at times.
