The Other Vehicle
YJ fan too. Best old school dash as well.
I agree they have the best dash.
Speaking of dash I just got the GPS calibrated in my YJ. Now the little house lights up when I’m close to home (;
Also, green is a great color for a YJ. Mine was the dark green color in a past life but currently wearing a TJ color.
You almost have to have it on if your on oversized tires and 3.07 gears! 5th is for flat or downhill highway only lol
The 4.6 stroker helps with the oversized tires, but not quite enough, I will be stealing the 3.73 gears out of my wife’s to bring it back to factory overall ratio… My wife’s YJ was a 2.5 automatic from the factory but is a 5 speed now, which would have 4.10 gears in it from the factory.
0-60 by next week if you’ve got a tailwind?
It’s really not bad at all around town on the roads especially if you’re used to 4cyl Toyotas running 40s. The difference with the Toyota is the crawl box setup makes it much lower gear off-road (~5x more low range)
These axles (and the 37s) came out of an old xj so they were already set up. If I geared them from scratch I would’ve installed 5.13s or built different axles with 5.38s but the “free” 4.88s and 37s are good enough for putzing around and the speedo is only off by 7%. Not sure what tooth gear equivalent because I’m running a jk style tone ring type speedo in a late np231 with true neutral behind an ax15
That’s quite a mutt of a setup you’re running, but sounds like good component choices. I’d imagine in Low Low 1st you can get out and spot yourself it’s moving so slow.
Top speed is ???
In high school (late 1970's) I drove a '57 Willy's with 3 speed. I had so much fun in that Jeep, had a plow on it. Only problem was if it had to go somewhere on the highway, you could push it to maybe 55 mph. And I don't know what the HP rating of the little 4 cylinder was, I would think under 100, but with the gearing it was more than powerful enough around town and in snow and dirt roads.
