Cummings!2029?
That’s normal if you have a single alternator. The grid heater is doing a post-heat cycle and takes a lot of power.
2029 at that!Cummings!
Back to the future...2029?
Thanks. Batteries were not strong enough to turn over engine. They needed replacement. While checking out electrical system was when I noticed the voltage delay issue.The alternator on my 2029 Ram 2500 Cummings Diesel takes almost a minute before it starts charging. Prior to the start of output, voltage can be as low as 11 volts. New batteries installed, same issue. is this normal?
