2022 68RFE dipstick part number
Trash Panda
Recently purchased a new-to-me 2022 ram 2500 with the 6.7/68RFE combo, and it has had the dealer recall for the transmission vent and dipstick done with the insane 15” “dipstick”.
I am posting to verify the correct part number for the actual locking dipstick, so that I can drop the pan & change the fluid to get the correct fluid level, as well as install my PPE pan & filters. I’ve tried with my local dealer, and they are of absolutely zero help.
I was given a revmax 4th Gen locking dipstick by a buddy, but I have been made to understand that Mopar has the correct part for the new trucks, and that part number is:
CSSPZA31AB​
Would anyone be able to verify fittment of this? Or at the very least inform me the measurements of the “min-max” range so that I can properly mark them on my revmax dipstick.
Thanks to all who read this!
-TP
CSSPZA31AB​
-TP
Ram revised that locking dipstick and updated it part way through the recall campaign. The latest one is 44” long, has the locking head, and can be used to check your fluid as normal. Ram put out a customer satisfaction campaign to replace all of those 15” dipsticks with the more recent useable one. You can contact a dealer and have them look it up. They order you the part free of charge. IMG_5019.jpeg
Ram revised that locking dipstick and updated it part way through the recall campaign. The latest one is 44” long, has the locking head, and can be used to check your fluid as normal. Ram put out a customer satisfaction campaign to replace all of those 15” dipsticks with the more recent useable one. You can contact a dealer and have them look it up. They order you the part free of charge. View attachment 68029
I took that exact notice to my local dealer here in Cheyenne, and I got a whole bunch of shrugs.
At this point, I’d rather order the correct part for 13 bucks, than waste diesel driving 45 minutes down to Fort Collins to a dealer that has a clue. Cowboy dodge here is truly next-level awful.
Is the part number I posted the correct new full length dipstick that they are offering?
I’m not sure if the number is correct. Where did you get that number?
Digging around the various forums. It’s popped up twice, but neither instance came with verification of fit.
I had to go back and dig through my recall notes. This is the most recent info I have, which showed the part number you listed as well as a photo someone shared of the updated design. IMG_1465.jpegIMG_1466.jpeg
I had to go back and dig through my recall notes. This is the most recent info I have, which showed the part number you listed as well as a photo someone shared of the updated design. View attachment 68030View attachment 68031
Awesome, I cannot thank you enough for sharing that.
I’m gonna go ahead and just order the correct part myself, seeing as I can’t even get my dealer to acknowledge that it exists, much less get them to order it for me. I do wonder why they spec’d a new dipstick tube, but I’m definitely not going to even bridge that conversation with the guys at Cowboy Dodge.
Mind blowing levels of incompetence there.
The new disptick tube has a flange for the new stick plug to grip.
I don't recall if anyone ever measured the ID or checked a new stick in an old tube for fitment.
Either way, I’ll just throw the new tube in, seeing as it shouldn’t take but about 10 minutes.
Coming from GM gassers the last 20 years, I have been throughly disappointed with the dealer support on this truck.
The new locking dipstick will fit in the original tube. That’s what I have in my truck now. It’s tight trying to get it out too. Have to unlock it and wiggle it to get it out. I checked it against the original non locking dipstick and it’s the same length. I started to go back and try to get the tube with the crimp in it but it holds very well in the original tube.
Yeah, the new dipstick fit the original tube just fine, but in the interest of having the recall parts all on together, I took the 10min to swap the tube out as well.
Probably me being more neurotic than anything, but better safe I guess?
After the show I had to put on to get the long locking dipstick, since it fit so well, I decided to just let it slide. Got the Y43 done yesterday by them and they didn’t seem to be holding a grudge.
Hey Trash Panda! Did you have to wait several hours or overnight to take out the old dipstick tube and install the new one? I'd like to avoid an eruption of 168 degree transmission fluid when I make the swap. Thanks!
Went to dealer that did the Za3 recall, and they won’t order, sell or replace the 44” dipstick. Went to 2 other dealer and no go. Service guy said I have to come in and have their dipstick to check fluid level wtf.
If anyone has the 44” dipstick, is the blade length 44” or length overall?
I bought a 68rfe dipstick on eBay and it’s not 44” in blade length or loa.
The pic shown of a locking dipstick- where did you buy it? It’s crazy that you have to go to dealer to check the trans oil level
Your dealer is incompetent
You don’t need to go to them, in order to check your fluid level. They should order the tube and locking stick for you, free of charge.
I went through the same issue.
When i heard about them giving the short dipstick for the recall I complained about it and finally received the full size stick, I got it for customer satisfaction mumbo jumbo...
They need to know their own system better.
And if this isn’t sufficient or they think you “made it up”, you can direct them to the National Highway Transportation Safety Administration‘s website where this is also available:
ZA3 Service Information - NHTSA
Solution: buy the parts from dealership ( the parts the dealership receives from mopar to do the recall):
CSSPZA31AB
Part Package
Each package contains the following components:
Quantity
Description
1
53032964AI (44" Dipstick and Tube) is the
As noted on thread, cost approximately $19 bucks. You receive the tube and 44” dipstick. My dealership Orange Coast in California refused the correct dipstick. It’s apparent the dealership gets the parts (tube and dipstick) but does not give that locking dipstick to the owner. Compared stock tube vs new part the new part has ridge to enable locking dipstick, when checked on my original dipstick has no ridge (perhaps the tube was not changed ????) Ram customer care is worthless. Contacted NHTSA regarding safety issue. Case has been opened.
All this for a dipstick from dealership that I should have received free.
Order it and be done. I had similar issues with my dealer, and the headache wasn’t worth the 19 bucks it cost to get it delivered to my house.
Yes just bought it at dealership $19 you can get it on ebay also, but went with the dealership about the same price, installed in my truck days ago
Thanks all for the leads
