DougB
I am getting an error message when trying to adjust the temps - Failed. Service Not Supported In Active Diagnostic Session. I am in the Windows/PC version using the OBDLink MX+.
It let me adjust them earlier but when I checked them, they were not what I had entered. One was close but the other is WAY off and now I cannot change them at all. Going to let the truck go to sleep for ~10 mins and retry later.
Heat default was 4.4 deg C (40 deg F). Vent default was 26.6 deg C (80 deg F).
Interestingly, the vented option would not let me go below the factory setting of 26.6 deg C. Posted an error message the number was out of range or too low, I forget the exact wording.
Edit 1: Tried later and no luck. Rebooted laptop and no luck. Guessing I am missing a procedural step somewhere.
Edit 2: Disconnected from Comfort module, reconnected/disconnected to Body module, then back to Comfort module. It no longer gives me the Failed error, says Procedure Completed, but the values do not stay saved.
Edit 3: Seems the range for the vented auto temp is 26.60 to 27.00. I set it to 26.82 and then it shows as 24.04 Deg C. 26.83 is the 26.6 deg C default setting. 26.81 is 21.48 deg C. There's some weird conversion going on there.
