Lady_Violet_XXI
Saga of the dead battery. Plot twist.
2021 2500 Big Horn
Push-button start. No remote start.
Bought used from dealer 2/23. 67k miles. Towed rv trailer with zero problems until 10/23.
> 9/28 - 2 safety recall repairs - IAGH relay replaced, tailgate striker inspected. Also had front end alignment and requested maintenance inspection (I suspect this last wasn't really done).
No immediate problems other than questionable alignment job.
> 3 weeks later. Rented a small uhaul trailer (5-pin plug). Stayed hitched overnight. Next morning won't start. Says wait for preheat. Flashed fuel filter message (odd because it had 40% life left).
Towed back to dealer. All they did was put on battery charger for several hours and started. Asked me if it was hooked up to anything (like a trailer). Yes. Was advised a short in the trailer electric probably drained battery. Also, primary battery would only charge to 80%, suggested I replace soon. Quoted $600, I decided to get the battery elsewhere. Drove it home.
> 2 days later, battery dead.
Called AAA to replace battery. Rookie hooked up packs to both batteries, no start. Says it's not batteries and leaves.
> I research. Find out you can't jump a diesel like that.
> 2nd call to AAA for battery. This guy does an actual test, charge etc. Primary battery tests bad, replaced. Starts fine.
> Zero problems for 2 months, even pulling rv, sitting several days etc.
>Wednesday (3 days ago) dead battery.
I hook up to jump vehicle, charge about 30 minutes, it starts. Plan to take it in until I see that dome light stays on, even after I'm driving. Suspect that drained battery while it sat 3 nights. Tech agrees. I plan to bring it in after holiday weekend. Make sure all lights go off after I lock it.
> Thursday, starts fine.
> Friday - Not as "dead" as before, but won't start. Diesel preheat cycling, "replace fuel filter" message then engine light. Just like first time. Alternator says 11v, but I don't know if that's an accurate read.
I've seen threads about trucks having parasitic draw, but this is bizzare. Dealer who performed recall says it can't be the new relay because it was fine for 3 weeks, so it must have been the rented trailer. I have no way to verify if they found a problem with that trailer after I returned it.
Everything seemed fine after the new battery. Now this.
Has anyone had problems following the relay recall fix? IF the rental trailer harmed the battery, that battery was replaced.
I'm taking it in to a place recommended by someone I trust. Now has 72k miles.
If you made it to the end, thanks.
2021 2500 Big Horn
