2019 SRW SB 4x4 6.7L
I'm trying to rotate my tires using a floor jack and jack stands. The owners manual clearly states where to position the jack for tire replacement (such as a flat tire). I can manage to get my jack and jack stand in the proper location at the rear, although its a very small window of lifting and placing the jack stand.
However, the front is a different story. There's no where relatively close by to lift the front end and place the jack stand at the intended lift point. The only other locations I see that could possibly be lifted from are the differential (large and small pumpkin in the front, which I'd rather not lift by), and the radius arm which has a flat piece of metal under it (maybe that's for a 2 post lift and can be utilized as a floor jack location?). I did however notice near the oil filter, the metal pan it gets set down in during removal/installation, was clearly marked on the bottom as "NO JACK".
So here's the question, where are ya'll lifting with a floor jack to be able to place the jack stand right next to the front wheels on the axle tube? Yes I want to use jack stands and not just rely on the floor jack while the wheel is off, and that particular location on the front axle tube is too close to the wheel to get the floor jack in there anyway. Thanks.
