oppizzippo
Awesome job! Count me in for one.M5 bolt through the rubber bumper for rotational stability and then uses the striker to bolt down solid.
I would be interested in one as wellM5 bolt through the rubber bumper for rotational stability and then uses the striker to bolt down solid.
That looks way better than the cheapo ebay one I have. As soon as you have them for order I'll be picking one up.
Thank you all! I'll post when the final version in done as a heads-up.I would be interested in one as well
Sent from my SM-S908U using Tapatalk
Looks real goodGot my wheel to wheel boards on today
Can you please post a pick er two with the wheel on. Thx.Installed Balance MastersView attachment 64547 Expensive but worth it, smooth as glass at any speed.
Installed Airlift 5000 air spring setup…..probably wouldn’t recommend that product though, their customer service sucked and the kit they sent me had been previously opened, fitted to something, scratched black finish off in a few okaces,and I had to enlarge some holes on one of the brackets as the spacing was off.
Now I get to see what air pressure will potentially help my ride compared to leveling out during towing.
I hope your quality control is better than mine. The “L”bracket that sits on top of the old bump stop was my issues.had to open up both holes on one side. Other side dropped right one. Also, had to use a pry bar to spread the upper bag mounts enough for the bolt holes to line up on both sides.I received my set on Friday but won't be installing them until tomorrow (that's the plan, anyway). The box mine came in was unopened, but all the pieces/parts appeared to be tossed in there willy-nilly without much consideration of the finish. There's some kind of waxy stuff on a couple pieces but other than that it appears to be complete and in good enough shape to live under the truck.
I had a set on a 2012 F250 years ago and used a single air fill point. Back then they used some kind of frosted plastic tubing that was tough to install without leaks. I think this time I'm going to install with the sides separated in order to enhance the stability while turning under load.
Pew pewI didn't do it but my drivers side window has a huge crack that appeared during my lunch run. I went into the store to grab a half roti chicken, came out and had a crack from the front bend down to the middle of the window. it looks like a rock/bb hit it in the middle of the crack - but not sure how a rock could have flung up and hit it. Strange.
yea - definitely weird, i'll take a picture when i'm off work in a few minutes, it's a small chunk in the center of the crack.Pew pew
NICE! Definitely interested in this. Whats the cost and how are they working? thank you!Installed Balance MastersView attachment 64547 Expensive but worth it, smooth as glass at any speed.
Lawnmower/weed wacker in the area?yea - definitely weird, i'll take a picture when i'm off work in a few minutes, it's a small chunk in the center of the crack.
I got them from CJC offroad, 201$ per axel. After driving them over the weekend at more highway speeds I feel like I still have some vibration in the steering wheel, but I can't say 100% sure it's tire related. They made a big difference over all. Before I had a lot of vibration in the steering wheel and hop in the seat at 60MPH, it's now basically smooth at any speed with a slight oscillation in the steering wheel. My small local shop installed the tires and they don't do road force balance, so I'm taking them to get road forced balanced tomorrow morning. I'm also having my alignment checked tomorrow to make sure there isn't anything going on there (my steering wheel isn't centered at the very least, so glad to get that fixed). I removed all the wheel weights today to see if that made any difference and I think it's slightly worse, so I think it's best to balance the tires first. Honestly no wheel weights + Balance masters are 100x better than what I had originally. Makes me wonder if I have a tire or wheel that has an issue. Hopefully road force balance will show that?!? Fingers crossed!NICE! Definitely interested in this. Whats the cost and how are they working? thank you!
Rocks be flyyen yoo. Driving the gravel roads around my place people have taken out their own side windows and sunroofs. Many including myself always drive the gravel with the sunshade closed just in case the weather is calling for glass showers. It sucks but at least it didn’t shatter…yet.I didn't do it but my drivers side window has a huge crack that appeared during my lunch run. I went into the store to grab a half roti chicken, came out and had a crack from the front bend down to the middle of the window. it looks like a rock/bb hit it in the middle of the crack - but not sure how a rock could have flung up and hit it. Strange.View attachment 64699View attachment 64700
