What’s your estimated tongue weight percentage with the enclosed trailer?
I strive for around 15%. I didn’t weigh the tongue today, I guessed on this load.What’s your estimated tongue weight percentage with the enclosed trailer?
Thanks it’s a 20’ with 7’ interior height to fit my rock crawler which barely fits.Looks great and love your trailer - that thing is so big it even makes your truck look kinda normal, lol. Anything special you want to share with us about the trailer?
I started with the Timbrens and went to SumoSprings because of the ride.Your tread inspired me to order some Timbrens. Hope they workout. By the way, love your trailer!
Still plenty of capability for that rear axle. Jealous your front weight is so low even with that bumper and winch.Weighed her this morning at cat scale #3310
No trailer
Pretty thick girl for a gas 2500
Still enjoying my sumos
YOU'RE GONNA DIE WITH NO SWAYBARS!!!!!!!! AAAAHHHHHH!!!!!!I’ve had the sumo springs for a while and a few months ago I decided to pull the rear sway bar off the truck and see how that felt.
After driving around a bunch and towing up through the mountains I decided the swaybar shouldn’t be on the floor in the garage anymore and I moved it to the spare pile in the backyard.
The sumo springs are handling everything quite well and I’m happy with the experience.
Gonna take more than that to kill me. This truck without sway bars body rolls less than my work truck 2016 tundra with TRD rear swaybar dealer add on.YOU'RE GONNA DIE WITH NO SWAYBARS!!!!!!!! AAAAHHHHHH!!!!!!
Looks sweet!
Look forward to hearing your experience if you’re happier with them shorter. For your use, you probably will be.Recip saw made quick work of minus two sumo bubbles leaving two, with them still on the truck.
The cuts left the end looking a little soft and airy, not quite like the surface originally on it.
Noticed that the driver side had an angle cut off the end in order to clear the pumpkin, looked like it was done with some kind of hot knife betcha, so made another like it.
Put the propane torch to the cuts, slightly toasted them making some god-awful no doubt deadly fumes.
When they cooled, the surface felt more like the rest…harder and seemingly more durable, albeit slightly bumpy. Tiny bumps.
Truck is heavy, man…slow dropping off of rocks especially on the downhill was more dramatic than would have been with pure spring travel imo and that is with a PW where there was some travel still available. I doubt there would be any with a standard 2500, would be on them static.Look forward to hearing your experience if you’re happier with them shorter. For your use, you probably will be.
If I did more off-road in this truck I would likely shorten up the sumos but for pounding pavement and putting in work I’m happy with them as is.
The suspension is not as soft as the payload numbers would have you believeSlightly off topic but I've always wondered how a PW would react to no swaybars being that the rest of the suspension is so soft.
I know I really like the disconnect when off road but the dang thing reconnects at a stupid low speed/wheel slip.....
lol the amount of squat under my 5k gross TT is embarrassing. The truck may be able to handle some weight but I'd need a paper bag over my head to drive it that wayThe suspension is not as soft as the payload numbers would have you believe
