Warranty
Nick
Ramona ,Ca
How long are the emission systems covered under warranty ?
If your vehicle is certified for sale and is registered in California, Colorado, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont or Washington, some emissions parts and performance are covered for 5 years or 50,000 miles while others are covered for 7 years or 70,000 miles. Additionally, vehicles registered in California (as I read it) must be repaired (under warranty) within 30 days.
For all others (in the United States) here is an "at a glance" warranty description:
Thanks for the information . The reason I asked Jason other forum a guy with a 2023 Dually had spent a total of over 4 k related to DPF problems his dealer said were not covered under warranty . I thought the guy was getting screwed royally by the dealer .
It gets pretty specific about what parts are covered and for how long:
5.1. FEDERAL EMISSION WARRANTY
A. PARTS COVERED FOR FIVE YEARS OR 50,000 MILES,
WHICHEVER OCCURS FIRST
If your vehicle is equipped, federal law requires FCA US LLC to warrant the
following emissions parts for five years or 50,000 miles, whichever occurs
first.
2500/3500 Diesel Engine
These parts are:
Accelerator Pedal
Assembly EGR By-Pass Valve Injector Connector
Accelerator Pedal
Position Sensor
EGR Temperature
Sensor Intake Air Heater
Active Grille Shutter EGR Tube Intake Manifold
ABS Speed Sensor EGR Valve Mass Airflow Sensor
Air Throttle Valve EGR Pressure Sensing
Tube
NOx Sensor
(downstream)
Ambient Air
Temperature Sensor
Emissions Label
Engine Oil Pressure Switch
Camshaft Exhaust Manifold/
Single
Oxidation Catalyst/
Particulate Filter
Assembly (DOC/DPF)
Camshaft Position
Sensor
Exhaust Temperature
TBAP Sensor
Particulate Matter
Sensor
Catalyst Assembly
(SCR/AMOx) Sensor -
After Treatment
Exhaust Pressure
Sensor
Powertrain Control
Module (PCM)
Charge Air Cooler
(CAC) Fuel Injector
Selective Catalytic
Reduction
Temperature Sensor
Crankcase Breather Fuel Pressure
Regulator TMAP Sensor
Crankcase Pressure
Sensor
Fuel Pressure Relief
Valve
Transmission Control
Module (TCM)
Crankshaft Position
Sensor
Fuel Pump - High
Pressure Turbocharger
Coolant Temperature
Sensor Fuel Rail Assembly Turbocharger Actuator
Diesel Exhaust Fluid
(DEF) Flange Module
Fuel Rail Pressure
Sensor
Turbocharger Speed
Sensor
DEF Injector Fuel Supply Line Upstream NOx Sensor
Differential Pressure
Fluid (DPF) Sensor Injector
Urea Tank Assembly
(includes pump, UQS,
level sensor, heater)
Exhaust Gas
Recirculation (EGR)
Cooler
B. PARTS COVERED FOR FIVE YEARS OR 100,000 MILES,
If your vehicle is equipped with one of the following parts, this Federal
Emission Warranty covers that part for a period of five years or
100,000 miles, whichever occurs first, calculated from the start date of
the Basic Limited Warranty as set forth in “section 2.1 E”.
In addition to the parts listed below, Air Conditioning (AC) components
whose failure would increase the emissions of AC refrigerants as a result
of a defect in materials and workmanship are also covered under this
warranty.
NOTE:
Where applicable with covered parts, associated plumbing, mounting
hardware, gaskets, O-rings, and wiring harnesses are covered. Where
parts are scheduled for replacement as required maintenance, this
warranty applies until the first scheduled maintenance point listed in the
Owner’s Manual.
3500/4500/5500 Ram Chassis Cab Diesel Engine
These parts are:
Aftertreatment
Electrical Connections DEF Dosing Valve Fuel Pressure Sensor
Aftertreatment Inlet
And Outlet Module DEF Module Fuel Pump
Aftertreatment
Temperature Interface
Module
DEF Temperature
Sensor Fuel Pump Actuator
Aftertreatment
Temperature Sensor Diesel Particulate Filter Grid Heater
Ambient Air
Temperature Sensor
Diesel Oxidation
Catalyst Intake Manifold
Camshaft Position
Sensor
Sensor
Intake Manifold Air
Temperature/Pressure
Sensor
Charge Air Cooler (CAC) Engine Control Module
(ECM) Mass Air Flow Sensor
Clean Idle Sticker Engine Oil Pressure
Sensor
On Board Diagnostic
(OBD) Connector
Coolant Temperature
Sensor Engine Out NOx Sensor OBD Malfunction
Indicator Light (MIL)
Crankcase Breather
Exhaust Gas Piping
From Turbocharger Out
To The Last
Aftertreatment Device
Particulate Matter
Sensor
Crankshaft Position
Sensor
Exhaust Gas Pressure
Sensor SCR Catalyst
Crankshaft Pressure
Sensor
Exhaust Gas
Recirculation (EGR)
Cooler
System Out NOx Sensor
(DEF) Dosing Unit
(Pump)
EGR Differential
Pressure Sensor Throttle Actuator/Valve
DEF Level Sensor EGR Temperature
Sensor Turbocharger
DEF Line Heater
Control Relay EGR Valve Turbocharger Actuator
DEF Quality Sensor Exhaust Manifold
Turbocharger
Compressor Inlet Air
Sensor
DEF Tank And Lines Exhaust Valve Turbocharger Speed
Sensor
DEF Tank Heater
Coolant Control Valve Fuel Injector
Wiring Harness
Circuits Connected At
Both Ends To Emission
Warrantable
Components
DEF Tank/Lines
Heating Elements Of
Exchanger And Pipe
Fuel Line
Electronic Modules
Associated With
Sensors Listed Above
As you can see, the DPF is warranted for 5 years or 50,000 miles. Back in 2017 when I purchased my F350 DRW I put my first 100,000 miles on it in ten months and very quickly ran out of warranty. It's kind of ironic - diesels work best when they are driven but the more you drive the sooner any warranty expires. After the warranties have expired if you slow down problems that would have once been covered but are not start to crop up.
