I have heard some needing too as well as modifying or cutting the heat shieldDid any of you have to deflate the tire to fit it in there ? Need to get one for mine as well.
I added a ratchet strap on mine because I'm paranoid the added weight would break the cable.
Believe the spare is a nitto trail grappler.What is the actual tire height that is the question.
Not every 35" is in fact a 35" tire, most are shorter some are just over 34".
If you post your tire brand and size I can look it up.
