RamThis2500
Interesting.. I'm looking at installing the rear Limited seats for the heat and vent option. Hmmmm
The rear seats aren’t an issue, just the fronts. The only thing with the rears is you need the buttons on the back of the center console, and populating the wiring for those. That’s a whole separate issue, and I’m working on the solution for that right now.Interesting.. I'm looking at installing the rear Limited seats for the heat and vent option. Hmmmm
Don't think I could own another new vehicle without them.I find the vented seats work well. Definitely, a nice option to have IMO.
It can be done that way, too. I’ll have to check and make sure this would be everything, but you would need:And thanks Jimmy07 for the replies. I wouldn't go for a full seat swap, was just curious if anyone added the fans.
Looks like the leather seat covers are different for the vented seats, so those would need to be changed also.It can be done that way, too. I’ll have to check and make sure this would be everything, but you would need:
Both front base seat cushions
Both front back seat cushions
The two fans for each seat
The two ventilation bags for each seat
Seat cushion harness for each seat
AlfaOBD to enable the vented seat settings
The seats would have to be almost completely disassembled to install the parts.
Have you tried putting a 2.2 ohm resistor in the seat airbag squib circuit, and also run a resistor from the passenger seat occupant detection signal to the return? That should make the airbag module a little happier.Now that we’ve cleared up the fact that a 2019-2021 HD ram can possibly only have front heated seats (it’s always been a standard feature on the Laramies in either 5 or 6 passenger seating)- yes, you can add heated/vented seats. All the body wiring is populated on the body harnesses for them to plug right in. You’ll need to use AlfaOBD to enable the feature. BUT...another member is going through this right now, I’ve been helping him along the way, and it’s been an absolute nightmare. The seats this member swapped in are from a limited, and the limited seats do not use side airbags in the seats, or an occupant detection sensor. I don’t know if this is the case for the Laramie heated/vented seats, but the new seats are reeking havoc on the airbag module. We’re still trying to iron it out, but I would either hold off, or make sure the set of seats you find have the side airbag option and occupant detection sensor.
Yes, 2 ohm resistor will kill the airbag fault, and 1k ohm will kill the occupant detection fault. But, we shouldn’t have to be doing that. It should be configurable in the BCM and ORCM.Have you tried putting a 2.2 ohm resistor in the seat airbag squib circuit, and also run a resistor from the passenger seat occupant detection signal to the return? That should make the airbag module a little happier.
Vented seats one of items we wanted but couldn’t get on loaded Big Horn. Work great. Laramie nicer.I find the vented seats work well. Definitely, a nice option to have IMO.
Any progress made on this? I recently swapped Laramie seats into my 2022 Tradesman. All power functions work, however the airbag light is on and there is a harness not plugged in on the right side of the driver seat since the plugs are different. Not sure if there is an adaptor harness or if I need to just buy the body wiring out of a laramie to make this all work correctly.Yes, 2 ohm resistor will kill the airbag fault, and 1k ohm will kill the occupant detection fault. But, we shouldn’t have to be doing that. It should be configurable in the BCM and ORCM.
I’ll actually have a chance to mess with this hands on in the next few weeks, as I’m swapping a set of limited seats in my truck that currently has occupant detection and squib. I’d rather get it figured out correctly than fool it, or swap the sensors over.
Quick update, the picture I attached above, the plug on the right actually had a cover on it, once i unsnapped the cover i was able to connect the plugs together. I believe at this point I should be able to enable the Heated/Cool function, but I am still dealing with the Airbag light issue. Has anyone come up with any fixes other than a resistor. The seats i got came out of a 2021 Laramie.Any progress made on this? I recently swapped Laramie seats into my 2022 Tradesman. All power functions work, however the airbag light is on and there is a harness not plugged in on the right side of the driver seat since the plugs are different. Not sure if there is an adaptor harness or if I need to just buy the body wiring out of a laramie to make this all work correctly.
Did this issue ever get figured out? I have swapped a limited interior into my 22 Laramie. And air bag light is and wondering if this is a simple fix or ?Now that we’ve cleared up the fact that a 2019-2021 HD ram can possibly only have front heated seats (it’s always been a standard feature on the Laramies in either 5 or 6 passenger seating)- yes, you can add heated/vented seats. All the body wiring is populated on the body harnesses for them to plug right in. You’ll need to use AlfaOBD to enable the feature. BUT...another member is going through this right now, I’ve been helping him along the way, and it’s been an absolute nightmare. The seats this member swapped in are from a limited, and the limited seats do not use side airbags in the seats, or an occupant detection sensor. I don’t know if this is the case for the Laramie heated/vented seats, but the new seats are wreaking havoc on the airbag module. We’re still trying to iron it out, but I would either hold off, or make sure the set of seats you find have the side airbag option and occupant detection sensor.
Trying to get rear heated seats to work on my 22 Laramie? Swapped seats out of a limited and console. The truck originally didn’t have rear heated seats. Everything plugged in ok. I think I have everything turned on with alfaobi but still not working. What did I miss? Please help?The rear seats aren’t an issue, just the fronts. The only thing with the rears is you need the buttons on the back of the center console, and populating the wiring for those. That’s a whole separate issue, and I’m working on the solution for that right now.
Where did you plug this into and what does it do?Quick update, the picture I attached above, the plug on the right actually had a cover on it, once i unsnapped the cover i was able to connect the plugs together. I believe at this point I should be able to enable the Heated/Cool function, but I am still dealing with the Airbag light issue. Has anyone come up with any fixes other than a resistor. The seats i got came out of a 2021 Laramie.
Were you able to find the solution to the center console wiring? I am wanting to add heated/cooled seats to my 2022. The connectors under the rear seat are fully populated but need to manage the switches.The rear seats aren’t an issue, just the fronts. The only thing with the rears is you need the buttons on the back of the center console, and populating the wiring for those. That’s a whole separate issue, and I’m working on the solution for that right now.
