Unable to pull the pin
Speaking of code, someone on the 5thgenrams site posted they got their seatbelt chime disabled on their 23.
Same steps but 5 belt clicks instead of 3.
Will have to try that on my Durango. Old procedure did not take.
I was changing the led settings on my friends 2014 2500 today and thought I was going to have to blow into the obd Bluetooth to get the tail light to quit throwing a code.
I heard the last update to AlfaOBD let’s you pull the pin and program fobs, any confirmation?
I can check tonight. I know he broke it for the pre-2019 rams on the last update, and was working on fixing that, but not sure about 2019+.
It ended up working for me. Thanks for posting that update.
Just to verify- this was on a 2023 with the new 12” digit instrument cluster?
It was on my 23 Durango I’d referenced in an earlier post in this thread. The 3 click method did not work for me, 5 click did the trick.
Any idea if its working in AlfaOBD? I'm going to order myself a fob if so.
Thanks guys, I was struggling with Alfa to read my pin. Had to get a little tricky with it just to recognize my truck as a 2023. Then the rolling 5 digit pin number. (WOW)
But Jscan took the wheel & pulled me through programming a new fob, & turning on remote start. Fantastic!
Tail gate dropped just with the fob programmed. (before remote start was enabled)
I'm doing same on my 2024 and just grabbed JScan. Thanks!
