Hard shifting 21 cummins
Deadbuck
My 21 cummins just started shifting hard from 1st to second. Any ideas? 39k miles. No lights on. Just wierd just started.
How has your driving style been? Same as always? The transmission does learn, and for instance if the truck is typically hooked to a trailer or heavy static load in the bed, then things change the trans may need to adapt to your new driving style.
To be honest.... I've been putting way more highway miles on it the last 4 weeks. Running up north after work every other day. Round trip 200 miles
I don’t believe that would cause any issues you are seeing. You may have a issue coming up but not enough of one to trigger a CEL. I assume you have checked your fluid for proper level and discoloration/burnt odor?
Yes sir. Was doing it before then it quit for month or so. Guess that's what warranty is for.
And it don't seem to do it all the time
Well if it ends up being something follow up with us, should be interesting to hear what the dealer says. good luck man.
To be honest with no CEL it could just need a relearn it does happen with these transmissions from time to time
