Burton12387
Any insight to any negative effects of just cutting off flow for the summer?
Has anyone figured out of this even fixes anything?
I just put a sock and vice grip on the discharge side of the heater core above the turbo just to test it.
Previously they best temps i would ever see out of the driver side dash was 54-55 degrees. With the clamp temp Installed it was 45-46 degrees, and back on par with the passenger vents.
This somewhat reassures me that I have a blend door sealing issue and not a refrigerant/software/ sensor issue.
I have an appt scheduled for Tuesday, but I’m debating not wasting my time, and risking the dealership screwing up something on the truck. But I’m also tempted to try and ask them to calibrate the doors? I’m still confident I’ll be told “operating as designed” I can see why there are some who do actually have good ac. Somewhere there must be a bad batch of blend doors or bad calibration of blend doors. Thankfully, you only have to remove the whole dash to evaluate or repair. Sigh. (They can calibrate with Autel or similar with no dash removal, you just won’t be able to see anything).
My efforts are probably better spent putting a valve on the inlet side of the heater core. What do you think? Ask to calibrate doors? Or just valve off the core.
I’ve worked in the automotive field for 20 years and I’ve never seen numbers that low. I’d check your equipment and there’s always a difference from one side to another.IView attachment 5074
I can report my passenger side is about 10 degrees cooler than my drivers side.
Driver side 40 avg
Passenger 30 avg
Side note: It feels cooler when I turn off my vented seats. This is with them off.
Today, I finished my experiment with the heater core valve. I believe I have proven the heater core loop significantly affects the air conditioning temperature.
Test Methodology:
Observations:
- The truck was cold and hadn't been run in 24 hours.
- I put digital thermometer probes in all 4 vents.
- I recorded the ambient temperature in all vents which was between 99 degrees and 104 degrees.
- The outside ambient temperature was recorded at 84 degrees.
- I started the truck and immediately put the air conditioning into manual LO mode with recirculation enabled. This eliminates the potential software/sensor problem because in LO mode the truck tries to reach 0 Celcius.
- Every 30 seconds, I logged the temperature reading on all 4 vents and I also recorded the engine temperature.
- Within 5 minutes, all 4 vents reached their low point, but the engine was still way below nominal operating temperature.
- I observed the vent temperatures started to increase as the engine temperature increased above 120 degrees.
- I continued to log the temperature of the vents and engine until the engine reached thermal equilibrium at 188 degrees.
- Once the engine reached thermal equilibrium, I closed the valve blocking the heater core loop.
- Within a few minutes the vent temperatures dropped noticeably. In particular, the driver's right vent dropped by 7 degrees.
- After the vents stabilized at their low temperature, I opened the valve blocking the heater core loop.
- The vent temperatures rose within a few minutes. The driver's right vent increased by 7 degrees.
- After the vents stabilized at their high temperature, I closed the valve blocking the heater core loop.
- Within a few minutes, the vent temperatures dropped by up to 7 degrees.
- Within a few minutes, the vent temperatures increased by up to 7 degrees.
- Closing the heater core loop causes the temperature to decrease by 7 degrees in the driver's right vent.
- Opening the heater core loop causes the temperature to increase by 7 degrees in the driver's right vent.
- The heater core loop is definitely interfering with the A/C .
- The driver's right vent is the most affected, while the passenger's left vent is the least affected.
- The driver's side always puts out warmer air than either of the passenger vents. If your passenger is complaining about it being too cold, they may be right.
- I did this experiment on an 84 degree day. I suspect the problem is worse when the ambient temperature is even hotter.
- I suspect there is a separate problem with the computer/sensors not being configured properly which is exacerbating the problem.
I uploaded a video to YouTube if you want to review the test methodology:
Here is a chart showing the vent temperature after closing and opening the valve blocking the heater core. The engine was at thermal equilibrium.
Edit: Here is another view of the same chart that is easier to read on a phone.
Anyone know what this magic “to spec” that FCA has is?
