Great looking stance on that! What are your wheel specs for that to not rub? Have you had a chance to flex it out at all? I've been looking for a 38 that would fill the arches better than my 37's. These seem to do nicelyView attachment 61308
FYI. 38x13.5x17 Pat XT’s do fit with just a 2” Thuren level kit. Minor trimming necessary.
The wheels are Raceline Avengers 17x9 20+ offset. Same as CJC recommends. I’m running Thuren 2” level kit and sway bar.Great looking stance on that! What are your wheel specs for that to not rub? Have you had a chance to flex it out at all? I've been looking for a 38 that would fill the arches better than my 37's. These seem to do nicely
Sent from my SM-S908U using Tapatalk
They work fine at full stuff…Great looking stance on that! What are your wheel specs for that to not rub? Have you had a chance to flex it out at all? I've been looking for a 38 that would fill the arches better than my 37's. These seem to do nicely
Shrugs... Had a JKU on 40”s and Fusion built axles last. A TJ on 35s before that. I live in Colorado. Off-road activities are my jam. I want my Ram to do stuff and things also.Too big for my taste, but I can understand the desire to run a tire that size.
Congrats!
Shrugs... Had a JKU on 40”s and Fusion built axles last. A TJ on 35s before that. I live in Colorado. Off-road activities are my jam. I want my Ram to do stuff and things also.![]()
Man I love that! I’ve got a 2022 Longhorn Limited Mega with rear air. All you added was the 2” level and your only rubbing in the back? I’ve seen those air ride links that raise the rear 1” for only $33.00.View attachment 61308
I have the 2” Thuren front coils. Your truck would take the 3” front spring for the same ride height. My front sits .5” lower than the stock rear now vs 2” stock. I had to trim about half an inch off the pinch welds behind the front tire for them to clear at full stuff. My truck has no fender trim of any kind so on mine the tires stick out maybe 1.5“-2”Man I love that! I’ve got a 2022 Longhorn Limited Mega with rear air. All you added was the 2” level and your only rubbing in the back? I’ve seen those air ride links that raise the rear 1” for only $33.00.
I noticed you have the Hemi, I’ve got the Cummins, is the front suspension even close?
How far are they outside the fender?
