On the left side of the photo your mount hole will line up on a curve in the plastic, center punch before you drill so it doesn't slide on you. On the right side the goal is to center the hole in the available space.
Hopefully this photo represents to you how its going to mount when you work on your alignment and the mount hole.
Cut this side first.
A straight cut is fine for now to get it sitting flush.
Now that its sitting flush, mount the light in the trim plate, stick it in the grille, and loosely set your grille trim on top of it.
And trace the contour you'll need to cut away next. The RC trim plates DO NOT sit under the grille trim pieces, they sit within them. Your grille trim piece push clips will not engage with the extra thickness under them.
