Here are the other two.Attached are the settings I use with OBDLink MX to monitor EGT temps. Last is a screenshot of temps towing my 6K TT up a mountain pass.
Any idea why mine would only display 0 degree on everything? I wasn’t driving but the truck was idling for 10+ minutes. Thanks!Here are the other two.
Are you deleted? If not then it should display it no issues.Any idea why mine would only display 0 degree on everything? I wasn’t driving but the truck was idling for 10+ minutes. Thanks!
The list of PIDs you are selecting from are either standard SAE PIDs, or PIDs specific to Dodge/Ram/Chrysler vehicles. However, not every PID applies to every vehicle. If the PID does not apply to your specific vehicle it will not display any data.Any idea why mine would only display 0 degree on everything? I wasn’t driving but the truck was idling for 10+ minutes. Thanks!
Yes I am. Will it not display if deleted?Are you deleted? If not then it should display it no issues.
Nope as your EGT sensors are mostly all gone with the stock exhaust and the ECM is not setup to read the one remaining sensor with the tuneYes I am. Will it not display if deleted?
Well ****… what’s the most cost efficient way for me to monitor EGTs then? Appreciate your response.Nope as your EGT sensors are mostly all gone with the stock exhaust and the ECM is not setup to read the one remaining sensor with the tune
Most have to fool the post turbo EGT sensor to keep the truck happy some tuners offer a kit to go to the #3 EGT sensor plug that you have to drill and tap the manifold like the edge probe you pictured.
