SpeyRam
Hey all. This is a maddening one. I’ve dropped many F-bombs discovering this heading out on a short camping/fishing trip with my 2 kids. I have a slide in truck camper and usually pull a drift boat behind it. Went to connect the 7-pin umbilical connector for the camper to the plug on the rear of truck for power and then then 4-pin connector for the drift boat trailer harness and you can’t plug them both in together. The spring-hinged protective doors prevent you from plugging in both together. Only 1 at a time. Can’t believe this poor design. I can likely shave away plastic from the doors to make it work but I just didn’t have enough time to do it as I had to get on the road and had to bring another vehicle to tow the drift boat. Has anyone encountered this same issue and found a way to solve it without modifying the plastic plug doors and housing?
