2019 2500 6.7 with motor replacement
Kpexpert
I looking on picking up a 2019 2500 6.7 with 180000 on the dash. At 165000 he blew the motor running high tune so purchased replacement motor from crashed truck with 20,000 miles on it. Is there serial number on motor that I could verify vin or go to ram and get details. Want to make sure he didn’t put so old junk motor.
On top of the valve cover is the esn (engine serial number) you can look up the details on the engine on Cummins quick serve website.
I checked that its the cover from original motor. Is that repeated somewhere else on block
I believe the ecm has the esn on it as well, but if that was also swapped then I don’t know of any other location on the block itself, maybe someone else will chime in.
