Fog light for 2019 Tradesman
Here is a listing of all of the parts needed to install halogen fog lights in a Tradesman (or an unequipped Bighorn). I just installed mine today.
Quanity
2) lamp-fog 68202187AA
1) Bracket - Fog lamp 68449383AA. both left and right sides come together.
1) Bezel- Fog light 68449341AA. Both left and right sides come together.
6) Bolt 68368951AA. These are to mount the fog light to the bracket.
8) Nut 68404464AA. These are j-nuts that go in the mounting holes in the bumper bracket so you can mount the fog light bracket to it.
8) Bolt- Hex Head 6508065AA. These screw into the j- nuts.
That's all you need...….now the stuff on the electrical end is another subject!
Thanks! Would you mind also detailing how many of the nuts and bolts you had to purchase as well?
Quanity. Price
2) lamp-fog 68202187AA $102.00 ea.
1) Bracket - Fog lamp 68449383AA. both left and right sides come together. $22.82
1) Bezel- Fog light 68449341AA. Both left and right sides come together. $13.68
6) Bolt 68368951AA. These are to mount the fog light to the bracket. $0.85 ea.
8) Nut 68404464AA. These are j-nuts that go in the mounting holes in the bumper bracket so you can mount the fog light bracket to it. $0.50 ea.
8) Bolt- Hex Head 6508065AA. These screw into the j- nuts. $1.39 ea.
That part number for fog lamp lists for a 2018 Jeep Renegade too. Those can be found online for Half the price.
Baja designs makes a nice plug and play set up. it's expensive but pretty sweet.
So the Fiat 500 uses the same Fog Lamp part number and I found this from Diode Dynamics. Link
I might give it a try. Looks familiar. Almost identical to Baja Designs.
Ignore the Fiat 500 comment. If ordering from Diode Dynamics just order the light for the Ram 1500.
Is this in addition to what's leftover from the screws holding in the blanks? I see in @TogaLock77's post above it looks like he was able to mount the bezels with the existing hardware. Thanks!
Yeah, you have to reuse the hardware that retain the blanks because the the fog light bezels don't include them.
That confirmed ? Those are pretty sleek looking and cheaper than buying halogen mopar.
that would be an awesome alternative.
I just realized I’m less than 5 min from Diode Dynamics. Their customer service is remote right now due to covid. I’m trying to track someone down to see if I can compare mounting brackets with theirs. We’ll see how willing they are to work with me.
I'd be a buyer for a set if they end up engaging with ya. that would be pretty cool.
The Diode Dynamics show room is closed so I can’t test fit them all. Shipping to me is free so I’ve ordered up a set. When they arrive I’ll update.
Finally got it done. Thanks to everyone for the great info. I disabled the Front Fog Lamp Drop Out feature so that the fog lights will stay one with the high beams. I also enabled the feature where they light up when you turn the wheel. I wired into the BCM connectors and used a factory light switch. That was tough to work on, very hard to get to.
Quanity. Price
not sure if youd know but if im going to run the baja designs kit id order everything besides the lamp fog?
